i need a drivers side door switch for a 71 cuda it has 3 taps on the wire where can i buy one thanks
Is yours a A01 car? There are several door switch types out there and getting the right one is difficult My 73 only has two wires, one each for the dome light and the other for the A01 lights. I bought a two terminal switch but it only made contact between the two circuits and not to ground. There is a workaround using the more common single wire switch to ground and diodes to do the same functions. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
