PIlot bearing retainer? #1409755
03/27/13 12:35 PM
03/27/13 12:35 PM
East Windsor, CT
CFster Offline OP
super street
CFster  Offline OP
super street
East Windsor, CT
Hi, looking for part numbers for the pilot bearing, and retainer (think that's what it's called) for an 18-spline A833 going into a '64 383.
-Colin
Re: PIlot bearing retainer? [Re: CFster] #1409756
03/27/13 12:56 PM
03/27/13 12:56 PM
Cab_Burge Online work
Cab_Burge  Online Work
-Colin
No retainer on the pilot bushing that goes into the crankshaft for the transmission input shaft Or are you talking about the front bearing in the transmission and the front bearing retainer If so conact either your local Dodge Chrysler dealer or better yet Dr Diff on here I think and hope he sells trans. parts
Re: PIlot bearing retainer? [Re: CFster] #1409757
03/27/13 01:39 PM
03/27/13 01:39 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Call Brewers, they do trans and are pretty close to Ct.
Re: PIlot bearing retainer? [Re: Challenger 1] #1409758
03/27/13 01:58 PM
03/27/13 01:58 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Here are pilot bearings & bushings:
http://www.brewersperformance.com/products.asp?cat=32
Here are 18 spline bearing retainers:
http://www.brewersperformance.com/products.asp?cat=81
Hope this helps.
A833 4-speeds, parts & services
