Denso alternator swap
#140969
10/24/08 01:04 PM
10/24/08 01:04 PM
Posts: 512 Sacramento, CA
Bdrainy
Sacramento, CA
I am considering doing to denso alternator swap and was looking at the info in the tech archives from AndyF. I see that the kit is sold through mancini to mount it, but looking at the picture the mounts look the same as whats on my 383 now. Is the denso a straight bolt on, or do I need to change the mounts? The picture may just be tricking me, but they look exactly the same to me... http://www.moparts.org/Tech/Archive/elec/34.html
Re: Denso alternator swap
[Re: Bdrainy]
#140971
10/24/08 03:23 PM
10/24/08 03:23 PM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
I dont know about anyone else, but I put an denso IR alt. off a toyota prerunner and just bolted it up to the stock mounts! Cant remember if I shimed it or not but it fits great.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
[Re: Lefty]
#140973
10/24/08 04:42 PM
10/24/08 04:42 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I love how clean your engine compartment is but I do question the location of the fuel filter...
Possible fire hazard on top of the alternator like that.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: kilroy]
#140976
12/25/08 05:10 PM
12/25/08 05:10 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Mine too.
[Re: rcannon440]
#140977
12/25/08 06:17 PM
12/25/08 06:17 PM
340dart4spd
Parts Problem
Parts Problem
What amp Denso Alternator did you use?
60 amp..here is what i have
[Re: MoparforLife]
#140978
12/25/08 09:38 PM
12/25/08 09:38 PM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
Mine too.
me too. except I used one off an 02 dodge ram van, 130 amp. I did have to trim one spacer, though. took about 5 minutes with a dremel.
It's a long read, but it shows how I did it and what parts I used. I was into the whole thing for under 150. but I also bought stuff to go from single to dual field: http://www.moparchat.com/forums/showthread.php?t=61642
[Re: Bdrainy]
#140983
12/26/08 10:33 PM
12/26/08 10:33 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
I needed more amps too, but took a different route. I had my squareback, dual-field alternator's stator rewound and heavy duty diodes installed at the local alternator shop for under $200.
Of course it bolts right up to the stock mount and looks bone stock for a 1970. It puts out 70 amps at idle and just over 125 amps above 2000 rpm. I upgraded the wiring and did the bulkhead/ameter bypass sugested in the article on Alpar.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Pool Fixer]
#140984
12/26/08 10:36 PM
12/26/08 10:36 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
90a Denso Stock brackets Stock heads Only modification was to trim the stud on the back. Just how it worked out for me on a Small Block. I would still like to get my hands on a smaller pulley for this alternator..or a larger crank pulley. We'll see, may be serpentine on a magnum block soon enough. But the charging at idle with 90w H4 lights on, stereo, electric fuel pump, and my fan pullin 25-30a...it's not quite enough at idle. http://www.goodysgotacuda.com/DensoUpgrade.html
[Re: Pool Fixer]
#140985
12/27/08 12:17 AM
12/27/08 12:17 AM
Posts: 31,046 Oregon
AndyF
small blocks are tight with stock heads and a stock alt. I was at a friends shop and he had an cuda with a small block and eddy's. he had to shave the head to get the stock alt to fit. Denso? forget it on that one. that is a situation where you need special brackets. I think they ended going with something out of a ford. could have been a denso, don't know.
Actually the Denso 60 amp alternators fit better on a SB Mopar with Edelbrock heads than do the original type alternators. A SB with Eddy heads is a great candidate for a Denso swap.
[Re: SRT8Challenger]
#140987
12/27/08 01:19 AM
12/27/08 01:19 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Goody, that is one clean shop you have there!Looks great! Nice and tidy, no wires hanging!! ED
Why thank you,
Now I just have to get around to welding up the holes and smoothing the bay up some.
