You Warlock/LRE oweners, Tuff wheel "?" #1409423
03/26/13 05:30 PM
03/26/13 05:30 PM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
All LRE trucks are column shift (correct?). What do they do to get the (Factory) adapter to work? Or do the LRE's have a special set up to make them work (or no adapters at all?). I'd like to put a Tuff wheel on my '76 Dodge P/U. But I just want this answered before I get into it and start looking.
Some pics would be nice too
Re: You Warlock/LRE oweners, Tuff wheel "?" [Re: bigblock340power] #1409424
03/26/13 07:35 PM
03/26/13 07:35 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
You confuse me unless there's a tilt column in your truck.
Re: You Warlock/LRE oweners, Tuff wheel "?" [Re: bigblock340power] #1409425
03/26/13 07:53 PM
03/26/13 07:53 PM
WV
Danny Offline
Danny  Offline
WV
Is your 76 truck a 4x4 or 2wd? The 4x4 has a different adapter because the steering shaft is a diffent size and also no master spline, they are not as easy to find. If it is 2wd I believe the adapters are the same as the cars.
Re: You Warlock/LRE oweners, Tuff wheel "?" [Re: Danny] #1409426
03/26/13 09:46 PM
03/26/13 09:46 PM
Elk Grove, Calif.
Elk Grove, Calif.
It is a 2wd.
Re: You Warlock/LRE oweners, Tuff wheel "?" [Re: Danny] #1409427
03/27/13 02:46 AM
03/27/13 02:46 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The FPB & FSM indicate that 4X4 & 2WD use the same steering wheel with the splines different between tilt & non tilt
Re: You Warlock/LRE oweners, Tuff wheel "?" [Re: bigblock340power] #1409428
03/27/13 04:39 AM
03/27/13 04:39 AM
Winnipeg, Manitoba, Canada
4dr4x4 Offline
mopar addict
4dr4x4  Offline
mopar addict
Check to see if your adapter and column have an index key, if one of them does not it's off a 4x4. Don't know much if anything about the 70's tilt columns, don't see them very often.
Re: You Warlock/LRE oweners, Tuff wheel "?" [Re: 4dr4x4] #1409429
03/27/13 05:40 AM
03/27/13 05:40 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Mike,
Another option is to use a repro wheel from Grant. They used to offer one that looked similar to the TUFF wheel but had slight differences. I'm sure it would be much cheaper than a NOS or even a decent used original Tuff.
The Mopar Action Bold Beeper has one of the Grant wheels. They did an article on the install a few years back.
Re: You Warlock/LRE oweners, Tuff wheel "?" [Re: BulletBob] #1409430
03/27/13 07:33 AM
03/27/13 07:33 AM
WV
Danny Offline
Danny  Offline
WV
Bulletbob you are right that the tilt does have a different spline, however the 4wd and 2wd spline is also different even if both are non tilt. I know a guy that grinded a few splines off a 4wd steering shaft to get the car tuff adapter to go on, still would not work. They are diffent.
Re: You Warlock/LRE oweners, Tuff wheel "?" [Re: Kern Dog] #1409431
03/27/13 11:45 AM
03/27/13 11:45 AM
Elk Grove, Calif.
Elk Grove, Calif.
Mike,
Yep, I've looked at them. I'm not opposed to them at all. You have anything I could use? I'm open to trades!
Re: You Warlock/LRE oweners, Tuff wheel "?" [Re: Danny] #1409432
03/27/13 12:20 PM
03/27/13 12:20 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I was going by the factory parts books
Re: You Warlock/LRE oweners, Tuff wheel "?" [Re: BulletBob] #1409433
03/27/13 12:31 PM
03/27/13 12:31 PM
foristell mo
serano Offline
serano  Offline
foristell mo
Yep-sometimes books can be deceiving.I have 2 wd tuff wheel adapters,tilt columns and a red tuff wheel-factory.But my adapters wont work on tilt or 4x4 columns
Re: You Warlock/LRE oweners, Tuff wheel "?" [Re: bigblock340power] #1409434
03/27/13 01:27 PM
03/27/13 01:27 PM
4dr4x4 Offline
mopar addict
4dr4x4  Offline
mopar addict
I have this wheel that came off a 79 LRE that I parted out a few years back, also think I still have the column here as well. And you don't need the adapter.
Re: You Warlock/LRE oweners, Tuff wheel "?" [Re: 4dr4x4] #1409435
04/01/13 10:14 AM
04/01/13 10:14 AM
Dearborn, Michigan
jstollfu Offline
jstollfu  Offline
Dearborn, Michigan
I used the repor Grant "Tuff" wheel and adapator in my 76 Dodge 2wd short box. I had no problems with the kit. It looks close enough to an original set up for me. Josh-
Re: You Warlock/LRE oweners, Tuff wheel "?" [Re: jstollfu] #1409436
04/01/13 02:32 PM
04/01/13 02:32 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
This is what the adapter or can looks like.
I am truckless..
Re: You Warlock/LRE oweners, Tuff wheel "?" [Re: 340SHORTY] #1409437
04/01/13 05:09 PM
04/01/13 05:09 PM
4dr4x4 Offline
mopar addict
4dr4x4  Offline
mopar addict
I've always thought about putting a stock E-body wheel in a truck, it looks good. I think I still have one kicking around here somewhere.
Re: You Warlock/LRE oweners, Tuff wheel "?" [Re: 4dr4x4] #1409438
04/01/13 08:20 PM
04/01/13 08:20 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Thats an "E" body wheel mounted on an "A" body can. I had tried using a Grant GT wheel but it obscured my vision of the insturment cluster.
I am truckless..
Re: You Warlock/LRE oweners, Tuff wheel "?" [Re: 340SHORTY] #1409439
04/01/13 09:18 PM
04/01/13 09:18 PM
Lehigh Acres, Florida
rickstershemi Offline
did you lose your pillow again....???
Rickster
Re: You Warlock/LRE oweners, Tuff wheel "?" [Re: rickstershemi] #1409440
04/02/13 12:23 AM
04/02/13 12:23 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Nope, my fat azz squished it..
I am truckless..
