Bad idler arm, PST super kit worth the $$$??? #1409412
03/26/13 05:03 PM
03/26/13 05:03 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
I have a worn idler arm on my 71 challenger. Are these PST kits worth the money? I have a friend who will help me do the labor.
http://www.p-s-t.com/s.nl/it.A/id.185/.f?sc=12
Thanks for any input
2016 Diesel Ram 3500 Mason Dump
1971 Challenger
2013 Jeep Wrangler
1979 Dodge Ram Power Wagon 400 Mini Pumper
My other car is a Fire Truck.
Re: Bad idler arm, PST super kit worth the $$$??? [Re: fireeng] #1409413
03/26/13 05:28 PM
03/26/13 05:28 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Before you purchase, you might want to investigate whether getting some offset upper control arm bushings might be worthwhile, to allow for getting a little more positive caster when you get the alignment done.
Additionally, getting some 11/16" tie rod ends and tie rod sleeves might be worthwhile also, to enhance tie rod end safety a bit.
That's why a lot of folks here piece things together a bit.
Some do polyurethane on the UCA bushings (and sometimes on the LCA bushings, as well). Kinda depends on how much you want to tighten things up.
Pressing the bushings out/in usually can't be done at home, unless you have/have access to a hydraulic press. Although there is a special tool kit made by American Muscle just for doing front end parts replacement (getting the ball joints separated from control arms, etc.).
If the idler is shot, might be worth checking the bushings and ball joints - they are common culprits in sloppy steering.
It's likely your cam bolts on the UCAs are okay, so that's four parts you probably wouldn't need anyway.
Re: Bad idler arm, PST super kit worth the $$$??? [Re: fireeng] #1409414
03/26/13 05:30 PM
03/26/13 05:30 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Its generally cheaper to goto a local auto parts store and get MOOG brand parts. Then youre assured of some kind of quality....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Bad idler arm, PST super kit worth the $$$??? [Re: HemiRick] #1409415
03/26/13 06:27 PM
03/26/13 06:27 PM
North Austin
KnuckleDuster Offline
North Austin
I used thier poly kit with 11/16 tie rods,but went with rubber LCA bushings and after trying to get the alignment done ended up needing the Moog offset UCA bushings to get +caster. I will just go all Moog next time. The Cardone remanned steering box I bought was way sloppy so I also switched to a Firm Feel stage 3 box,expensive but easily the best spent money on the car! Handles great,nice and tight!
The tool for the UCA's was a good deal since I have other vehicles to do but I paid a shop to swap in the LCA bushings,to me it wasn't worth the hassle to do those myself
Re: Bad idler arm, PST super kit worth the $$$??? [Re: KnuckleDuster] #1409416
03/26/13 07:18 PM
03/26/13 07:18 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
pst uses cheap parts...ergo the cheap price. its prob fine if your car sees 1000 miles a year but dont expect it to last in daily driver duty.
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Bad idler arm, PST super kit worth the $$$??? [Re: pnypwr] #1409417
03/26/13 11:11 PM
03/26/13 11:11 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
How does the price on this kit look?
http://www.carpartsdiscount.com/auto/par...tml?3593=336172
What else needs to be added to make it comparable to the pst kit?
Thanks for looking
1971 Challenger
2013 Jeep Wrangler
Re: Bad idler arm, PST super kit worth the $$$??? [Re: fireeng] #1409418
03/26/13 11:34 PM
03/26/13 11:34 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
looks pretty complete to me, I buy the moog stuff from my local jobber, and then ill run energy bushing if I want poly or stock rubber in moog. I like to deal locally so when I have a warranty issue I dont have to deal with some fly by night ham and egger company. moog parts can fail too, ive warranteed several ball joints and tre's but theyre usually on heavier overworked under maintained trucks
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Bad idler arm, PST super kit worth the $$$??? [Re: fireeng] #1409419
03/26/13 11:40 PM
03/26/13 11:40 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
I bought the super PST kit, mainly because my car has 160,000 miles on it. But after I started taking the front end apart, I realized that many parts, including the lower ball joints were NOT worn out, and buying the super kit was a waste.
For example, the factory service manual warns about not replacing lower ball joints until 0.070" axial movement in the housing arm relative to the ball joint stud is reached.
I should add that when I discovered that PST's strut rod grommets were way too big, PST's tech dept was absolutely no help. They suggested I use a sawzall to cut 'em down to size.
Not to mention that almost nothing in the PST kit looks Mopar original.
You'll save money by inspecting the components one by one and buying what you need. Or, you can buy my super kit from me.
Re: Bad idler arm, PST super kit worth the $$$??? [Re: kentj340] #1409420
03/27/13 12:07 PM
03/27/13 12:07 PM
Dyno1 Offline
Dyno1  Offline
I have used the bushing kits from Prothane, nice parts and available from Jegs or Summit. Dyno
Re: Bad idler arm, PST super kit worth the $$$??? [Re: kentj340] #1409421
03/27/13 12:08 PM
03/27/13 12:08 PM
North Austin
North Austin
"I should add that when I discovered that PST's strut rod grommets were way too big, PST's tech dept was absolutely no help. They suggested I use a sawzall to cut 'em down to size. "
Lol...forgot about that part,I cut mine,ditched the sleeves,and they work fine.
Re: Bad idler arm, PST super kit worth the $$$??? [Re: fireeng] #1409422
03/28/13 03:13 PM
03/28/13 03:13 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
Thanks for looking
Moog Kit ordered, $339 delivered to my door! New front end on the way!
1971 Challenger
2013 Jeep Wrangler
