Np435 strength #1409399
03/26/13 04:55 PM
03/26/13 04:55 PM
Iowa
76dodgeboy Offline OP
Iowa
How much horsepower can one handle? Thanks
Re: Np435 strength [Re: 76dodgeboy] #1409400
03/26/13 05:14 PM
03/26/13 05:14 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I new a guy that pulled in 2wd class with a 482ci with aprox 650 horse and never had a 435 fail,but like with everything some go and some blow
Re: Np435 strength [Re: 76dodgeboy] #1409401
03/26/13 05:19 PM
03/26/13 05:19 PM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
It would depend on how much the vehicle weighs. I had one in a D-600 w/361 and held up fine for years sometimes weighing over 30k. Ive ran them in pickups with 400-500 hp and they did fine but the big clutch doesnt like disengaging at high rpm. I would think it's as strong as a 18 spline.
Re: Np435 strength [Re: Handygun] #1409402
03/26/13 07:48 PM
03/26/13 07:48 PM
Iowa
Iowa
Dont know what an 18 spline is. My motor is estimated at 510hp
Re: Np435 strength [Re: 76dodgeboy] #1409403
03/26/13 08:06 PM
03/26/13 08:06 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
I broke the mainshaft in my '86 W250 with a 550 hp 440 in front of it. That was truck pulling though. Truck started bouncing at the end of the track and it snapped. If you are not going to pull it, You should be ok.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Np435 strength [Re: 71yelladustr] #1409404
03/26/13 08:51 PM
03/26/13 08:51 PM
Coeur d Alene, Idaho
jimbob101 Offline
jimbob101  Offline
This Super Stock pulling truck (6200lbs) runs a 530cid rated at 900hp or a little more I think, and he runs the NP435 4th gear (1:1) dual disc clutch with a Profab reverser (choose your gearset) transfer case and rockwell 1 speed rear end, and has been running if for 15-18yrs and hasn't broken it yet! I think that's amazing..!
Re: Np435 strength [Re: jimbob101] #1409405
03/26/13 08:57 PM
03/26/13 08:57 PM
jimbob101 Offline
jimbob101  Offline
Here's a video of it pulling, that thing has a NP435 in it..
http://www.youtube.com/watch?v=fdGUXZoLrnc
-J
Re: Np435 strength [Re: jimbob101] #1409406
03/27/13 02:33 AM
03/27/13 02:33 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I had one & everything hooked behind it broke until it got 60's then it was mostly drive shafts & transfercase Ripped the center out of a stock clutch once Survived drunken 4 wheel burnouts with 44's
I've got a buddy that used to go clutchless with his Imagine a guy who can lift & is strong snatching a shorty 435 shifter at 6500 RPM
Re: Np435 strength [Re: BulletBob] #1409407
03/27/13 04:00 AM
03/27/13 04:00 AM
Iowa
Iowa
D60s will be present with 4.88s and 37s
Re: Np435 strength [Re: 76dodgeboy] #1409408
03/27/13 09:09 AM
03/27/13 09:09 AM
Lenox Iowa
MMiller Offline
MMiller  Offline
Lenox Iowa
IMHO the clutch(unless you are putting a twin disc in) will not handle as much abuse as the NP435 will. Everything else around it will fail first in most instances. I understand that in a larger truck application that a larger input shaft was available. If you haven't purchased a clutch yet, you might look into that......but in all reality, I would not worry one iota about it. Fill it with oil and run it.
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver,
90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
Re: Np435 strength [Re: MMiller] #1409409
03/27/13 02:29 PM
03/27/13 02:29 PM
Iowa
Iowa
Its going to be for mudding and some light crawling
Re: Np435 strength [Re: 76dodgeboy] #1409410
03/27/13 02:52 PM
03/27/13 02:52 PM
Lenox Iowa
MMiller Offline
MMiller  Offline
Lenox Iowa
It will be fine.
Re: Np435 strength [Re: MMiller] #1409411
03/28/13 12:43 AM
03/28/13 12:43 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The only one I ever saw broke was broken at the shifter. The fool had a messed up clutch so he would start the truck in neutral and force it into gear to get moving and power shifted from there, up and down through the gears. After about a year (no lie, nearly a full year) he broke the shifter lever, which someone welded back together for him 2 times. He brought the shifter handle to me and I fixed it good enough he finally broke the shifter tower off the top of the trans.
Those transmissions are tough. Gene
