Something missing on these brakes? #140900
10/24/08 12:42 PM
10/24/08 12:42 PM
St. John's Newfoundland
440newport Offline OP
I'm working on a 90 W150 I just bought, changing the handbrake cables because they're seized. So I take the drums off and see this on both sides. Are the emergency brake crossbars missing? Or are these brakes like this? I can't see it working like this. The pivot arm appears to be bent as well. Now I gotta drive back to the scrapyard again.
Re: Something missing on these brakes? [Re: 440newport] #140901
10/24/08 12:45 PM
10/24/08 12:45 PM
yes, the cross bar is not there and there is no self adjusting cable either
Re: Something missing on these brakes? #140902
10/24/08 12:51 PM
10/24/08 12:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Self adjuster isn't necessary but the crossbar is.
Re: Something missing on these brakes? [Re: 440newport] #140903
10/24/08 01:08 PM
10/24/08 01:08 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
[quote} The pivot arm appears to be bent as well. Now I gotta drive back to the scrapyard again.
You mean this? I believe that part is supposed to be like that. It gives the spring that goes there more surface to ride on.
Re: Something missing on these brakes? [Re: Scott Carl] #140904
10/24/08 01:10 PM
10/24/08 01:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Scott you do know that you can edit or delete your post when they don't come out right don't you?
Re: Something missing on these brakes? [Re: stumpy] #140905
10/24/08 01:53 PM
10/24/08 01:53 PM
yo can?
Re: Something missing on these brakes? #140906
10/24/08 01:53 PM
10/24/08 01:53 PM
I mean, How?
Re: Something missing on these brakes? #140907
10/24/08 01:59 PM
10/24/08 01:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
By clicking on the edit link at the top right hand side of your post. That takes you to your post page and under the bunch of icons you will see a grey box that says "change this post" and "delete this post".
Re: Something missing on these brakes? [Re: stumpy] #140908
10/24/08 02:02 PM
10/24/08 02:02 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
OOps. I did but didn't look again after it worked. Deleting now
Re: Something missing on these brakes? [Re: Scott Carl] #140909
10/24/08 04:59 PM
10/24/08 04:59 PM
I got an old self adjuster off a C body rear end I had and had to go to a yard to get the crossbar, turns out I already had one but had to go get another. problem is though it doesn't want to go back together, it's as if the crossbar is too long or I have the wrong brake cable. I hooked the cable to the bracket on the frame first then hooked it up to the pivot arm and it wasn't easy to get on, as the cable already had some strain on it, making if very hard to push the spring back to get the arm on. Now the whole mess is lopsided and the right side pushrod is pointed way up. Hard to see in the pic whats going on. I can't see cable being the wrong one, the guy said there is only one right rear cable listed and he double checked the part #.
Re: Something missing on these brakes? [Re: 440newport] #140910
10/24/08 05:09 PM
10/24/08 05:09 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
If the brake lever is releasing far enough, it should almost touch the pin that holds brake shoes to backing plate. I'm assuming you got the cross bar from another 11 inch brake setup? That's what the truck has, no? Also, you have adjuster cable in between return springs instead of behind them both, although that's not related to brake lever isssue. Be certain the cables are releasing all the way, you may have to back adjuster off at cable, stuffs probably frozen(rust)
Re: Something missing on these brakes? [Re: buildanother] #140911
10/24/08 05:17 PM
10/24/08 05:17 PM
Yeah I put the cable in between them because that diamond shaped thing is loose and it wouldn't stay put when I tried to put the spring on after.
The truck has 11x2.5 brakes and that's what the crossbar and adjuster are from. In this pic you can see the pivot is pretty far from the shoe though, I guess the cable is too tight? It is released all the the way though, in fact the frame bracket cable isn't even hooked up right now so everything is loose.
Re: Something missing on these brakes? [Re: 440newport] #140912
10/24/08 05:23 PM
10/24/08 05:23 PM
Here's the frame end, see that the cable that pulls the bracket forward isn't even hooked up right now. But notice the new cable doesn't stick out of the sleeve as far as the older one for the left side...
Re: Something missing on these brakes? [Re: 440newport] #140913
10/24/08 06:13 PM
10/24/08 06:13 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Looks like the new cable is to short & it's appling the parking brake, try disconnecting it from the equalizer bar allowing the cable to move further releasing the tension on the brake...
Re: Something missing on these brakes? [Re: Scott Carl] #140914
10/24/08 06:38 PM
10/24/08 06:38 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
OOps. after looking at pics and comparing to others I realize the spring goes on the opposite as I was thinking. But as you no doubt have found, that piece is supposed to have that little bent tab But heres a fairly good pic of what they should look like
Re: Something missing on these brakes? [Re: stumpy] #140915
10/24/08 06:50 PM
10/24/08 06:50 PM
Dexter, Michigan
copper67440 Offline
mopar addict
copper67440  Offline
mopar addict
Dexter, Michigan
Not to hijack, buuuuutttt, how will the brakes act if you don't have a crossbar in? I don't, but I haven't driven my car yet, having problems getting to bleed.
Re: Something missing on these brakes? [Re: copper67440] #140916
10/24/08 06:52 PM
10/24/08 06:52 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I think the cross bar is just there to actuate the e-brake. No bar:no e-brake.
Re: Something missing on these brakes? [Re: Scott Carl] #140917
10/24/08 09:10 PM
10/24/08 09:10 PM
RapidRobert Online content
RapidRobert  Online Content
I think the cross bar is just there to actuate the e-brake. No bar:no e-brake and
& the bleeding issue is a seperate problem
