Re: Something missing on these brakes?
[Re: 440newport]
#140901
10/24/08 12:45 PM
10/24/08 12:45 PM
yes, the cross bar is not there and there is no self adjusting cable either
[Re: stumpy]
#140905
10/24/08 01:53 PM
10/24/08 01:53 PM
#140906
10/24/08 01:53 PM
10/24/08 01:53 PM
#140907
10/24/08 01:59 PM
10/24/08 01:59 PM
Posts: 32,957 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
By clicking on the edit link at the top right hand side of your post. That takes you to your post page and under the bunch of icons you will see a grey box that says "change this post" and "delete this post".
[Re: stumpy]
#140908
10/24/08 02:02 PM
10/24/08 02:02 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
Scott you do know that you can edit or delete your post when they don't come out right don't you?
OOps. I did but didn't look again after it worked. Deleting now
[Re: 440newport]
#140910
10/24/08 05:09 PM
10/24/08 05:09 PM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
If the brake lever is releasing far enough, it should almost touch the pin that holds brake shoes to backing plate. I'm assuming you got the cross bar from another 11 inch brake setup? That's what the truck has, no? Also, you have adjuster cable in between return springs instead of behind them both, although that's not related to brake lever isssue. Be certain the cables are releasing all the way, you may have to back adjuster off at cable, stuffs probably frozen(rust)
[Re: Scott Carl]
#140914
10/24/08 06:38 PM
10/24/08 06:38 PM
Scott Carl
Omaha, Nebraska
[quote} The pivot arm appears to be bent as well. Now I gotta drive back to the scrapyard again.
You mean this? I believe that part is supposed to be like that. It gives the spring that goes there more surface to ride on.
OOps. after looking at pics and comparing to others I realize the spring goes on the opposite as I was thinking. But as you no doubt have found, that piece is supposed to have that little bent tab But heres a fairly good pic of what they should look like
[Re: stumpy]
#140915
10/24/08 06:50 PM
10/24/08 06:50 PM
Posts: 819 Dexter, Michigan
copper67440
mopar addict
mopar addict
Dexter, Michigan
Self adjuster isn't necessary but the crossbar is.
Not to hijack, buuuuutttt, how will the brakes act if you don't have a crossbar in? I don't, but I haven't driven my car yet, having problems getting to bleed.
