While checking retainer to guide clearance, you can check the installed height as well. That will help in determining if and which replacement springs are needed. I don't know what pressures the OEM crate springs are, but something around 130-150 seat and 320-350 open should work.
Coil bind and guide clearance need to be checked.
I got to liking beehive springs (Lots of rocker arm clearance.) Here is a Comp Cams example, but again, gotta check your existing installed height & related measurements. These would also require locks. I don't recall if Comp has "+" or "-" .050" locks for them in your valve stem size. If your IH is under 1.75" it probably wouldn't work.
* Comp Cams Beehive Springs 26918-16
- 125lbs @ 1.800"
- 367lbs @ 1.160"
- Spring rate: 373lbs/in
- Coil bind - 1.100"
* Comp Cams Steel Retainers 795-16
- For above beehive springs
- 1.096" diameter
- For 10* locks
I know where you can get some if confirmed they would work!
