68' Fender Marker Thread?
#1408285
03/24/13 10:03 PM
03/24/13 10:03 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
Front and rear markers on a 68 Dart. Is the thread standard size? They use the sheetmetal "nuts" to hold them on. my fiberglass fenders are much thicker than the sheetmetal, so I need to come up with something. Thanks.
383, Hemi 4-Speed, AlterKtion, D60
Re: 68' Fender Marker Thread?
[Re: Crazy68Dart]
#1408286
03/24/13 10:55 PM
03/24/13 10:55 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
Couldn't you grind/sand the back side around the hole to a thinner dimension? I'd think you could do that relatively easily. Also, the nut might be able to be modified to allow a greater depth
Once I can get to my garage I can check the threads with a pitch gauge.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: buildanother]
#1408291
03/25/13 11:33 AM
03/25/13 11:33 AM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
Plus, aren't they a 1 wire socket? Meaning you'll have to add a ground wire too.
That too...
[Re: Jim_Lusk]
#1408292
03/25/13 11:32 PM
03/25/13 11:32 PM
Crazy68Dart
Canton, Ohio
I think I will just section the nut to gain some depth. Not going to grind on the fenders with them already painted. And yeah...already added the ground wire to each.
