Re: 426 Hemi head with damage
[Re: Bull1tt]
#1408274
03/24/13 10:30 PM
03/24/13 10:30 PM
Posts: 155 my state of mind
jimkn
my state of mind
jb weld honestly i wouldnt worry about it to much unless your building a serious race motor as there for the valley studs, maybe if you want to sleep better have them cold stitched & forget about it!!!
" if you didn't own it since new then the fender tag is fake "
[Re: Bull1tt]
#1408276
03/24/13 11:21 PM
03/24/13 11:21 PM
Posts: 4,799 ILL
MLR426
ILL
this long crack can be felt with your fingernail.
I can fix this head but have questions. The long one you said you can catch your nail on it ? Does it keep going off the head deck and around and down across the intake seat and pass into the throat below the seat ? The head stud cracks I would stitch pin them on both sides of the threaded hole to stop cracking and then drill and install a time sert. I would also stitch pin the deck crack and possibly install a new seat if needed. After repair the head would have to be surfaced to clean up the deck surface. If the deck crack goes well into the intake throat area where you cannot get to it then the head will have to be welded with cast iron rod to fix it right which is a more extensive repair.
MLR426
[Re: MLR426]
#1408279
03/25/13 11:11 PM
03/25/13 11:11 PM
Posts: 1,606 Pgh, PA
Bull1tt
Pgh, PA
MLR426
I went and looked this head over tonight. I could not see any sign of the crack anywhere other than the deck. No sign down to the seat area or beyond. Even had an extra set of eyes from a buddy studying as well.
[Re: FM3_1970]
#1408280
03/25/13 11:14 PM
03/25/13 11:14 PM
Bull1tt
Pgh, PA
Did you mean to post this in the Ebay/WIW section? Might get more opinions if it was in Q & A or Race.
Move it to the Q&A, fine by me!
[Re: Bull1tt]
#1408282
03/26/13 10:40 PM
03/26/13 10:40 PM
Posts: 4,799 ILL
MLR426
ILL
MLR426
Have them dyed or mag them and pressure test, the tricky part is the crack is on a fire ring area. Are you sure it's a crack ?? Strange place for crack.
MLR426
[Re: MLR426]
#1408283
03/26/13 11:00 PM
03/26/13 11:00 PM
Bull1tt
Pgh, PA
MLR426
MLR426
It's like somebody tried to pry the head off an engine with those two bolts still in!
[Re: Bull1tt]
#1408284
03/27/13 02:06 AM
03/27/13 02:06 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Mag it.It can be welded and will be as good as new if done properly.If there isn't anyone local to you who can do it I have someone up here who can.It will need to be resurfaced.
Leave the gun.......take the Cannoli's....Mike
