Dye dash pad or buy repop? #1408227
03/24/13 07:44 PM
03/24/13 07:44 PM
NE Iowa
Road_RunnerSteve Offline OP
NE Iowa
My 71 Roadrunner project will need a dash pad. I have a mint green one from a donor car. Is there a dye process to change it to black that I would be happy with or should I plan on buying a reproduction?
Re: Dye dash pad or buy repop? [Re: Road_RunnerSteve] #1408228
03/24/13 07:47 PM
03/24/13 07:47 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
There is no dye that will soak in like it does with cloth. There are flexible paints like the ones SEM makes. Many have used with nice results. I like the SEM landau black. I've done an entire interior with it, minus seats of course. It gives a very OEM type appearance.
Re: Dye dash pad or buy repop? [Re: DaytonaTurbo] #1408229
03/24/13 07:54 PM
03/24/13 07:54 PM
IN
ahy Offline
ahy  Offline
IN
I have used the SEM product also. Eastwood sells a 3 part kit with cleaner, adhesion promoter and dye. I've had good results with it.
Re: Dye dash pad or buy repop? [Re: ahy] #1408230
03/24/13 08:28 PM
03/24/13 08:28 PM
NE Iowa
NE Iowa
That sounds like the way to go. Thanks!
Re: Dye dash pad or buy repop? [Re: Road_RunnerSteve] #1408231
03/24/13 09:27 PM
03/24/13 09:27 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
If you want it to look good I would sell the green one and buy another.
Re: Dye dash pad or buy repop? [Re: west] #1408232
03/24/13 09:30 PM
03/24/13 09:30 PM
NE Iowa
NE Iowa
Anybody have pictures to compare?
Re: Dye dash pad or buy repop? [Re: Road_RunnerSteve] #1408233
03/24/13 09:37 PM
03/24/13 09:37 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Going black I would dye it for sure. The repops don't fit or look like an original pad.
Sheldon
Re: Dye dash pad or buy repop? [Re: RUNCHARGER] #1408234
03/24/13 09:44 PM
03/24/13 09:44 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Sheldon
Just dye the original.
The original colored pads and armrests were dyed. Sometimes they are molded in a skin that has the same base color, but they are still dyed. You can see in the worn corners of a piece.
Re: Dye dash pad or buy repop? [Re: autoxcuda] #1408235
03/25/13 01:07 PM
03/25/13 01:07 PM
NE Iowa
NE Iowa
Thank you all for the advice. That was my main concern with the repops.
