Re: max wedge B1BS heads max cubic inch [Re: Cab_Burge] #1408194
03/26/13 02:20 PM
03/26/13 02:20 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
RT540 please post that dyno sheet and tell us what the motor has.
2011 Drag Pak Challenger
Re: max wedge B1BS heads max cubic inch [Re: HotRodDave] #1408195
03/26/13 02:52 PM
03/26/13 02:52 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
As for the B1BS it is a big head
Compared to what?
I have a set of BS heads...IMO they arent what I would call a "Big" head. They are barely above a CNC'dRPM, CNC'd Stealth, etc.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: max wedge B1BS heads max cubic inch [Re: Von] #1408196
03/26/13 03:15 PM
03/26/13 03:15 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Motor was built in -99, not in my ownership.
Heads are now on another motor, and my 540 will have B1originals, not because I didnīt like it, but the go faster...
MW Indy 440-1 intake
1050-9375 carb
Wiseco 13:1 flat tops
BME 426 7.15 rods
Crane superstock grind Int 0.707" Exh 0.670
276° dur at 050
4.50 bore, 4.25 stroke
Dry sump oil
Re: max wedge B1BS heads max cubic inch [Re: RT540] #1408197
03/26/13 03:24 PM
03/26/13 03:24 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Re: max wedge B1BS heads max cubic inch [Re: RT540] #1408198
03/26/13 03:31 PM
03/26/13 03:31 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Nice. Within 1% of max power at 5900. 800 hp and no need to rev it high. My buddy has B1BS's and I like them.
Re: max wedge B1BS heads max cubic inch [Re: RT540] #1408199
03/27/13 02:16 AM
03/27/13 02:16 AM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
thanx for posting dyno sheet
Re: max wedge B1BS heads max cubic inch [Re: 71Pan] #1408200
03/27/13 11:17 PM
03/27/13 11:17 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What are the B1BS's peers? Would it be the Edelbrock Victor and Indy 440-1?
Re: max wedge B1BS heads max cubic inch [Re: WO23Coronet] #1408201
03/28/13 12:09 AM
03/28/13 12:09 AM
I had Jeff at Modern cylinder heads CNC port a set of stock B1-BS to M.W. size, they flowed(intakes) 350 CFM at .600 on a Super Flow 600 bench at 28 inches of water, I have a set of Indy SR that where M.W. port size when I bought them used, they flowed 340 CFM on the same bench by the same tech. on a different day Both the SR and the B1-BS have the standard rocker arms, pushrod pinch and intake valve spacing like the stock 361/440 have so that is probally the limiting factor on how good you can get them to flow My CNC ported 440-1 flowed 370 CFM on the same bench at the same specs I swapped the SR to the 440-1 on two different motors that I ended up dyno testing both motors on a back to back tests and both motors changed 50 HP
