Exchange Flowmasters for Walkers on 69 Coronet question
#1407542
03/24/13 10:47 AM
03/24/13 10:47 AM
Posts: 683 Northern NJ
68 Sat
Northern NJ
I have a 69 Coronet 500 with a 318 with full 2 1/4" dual exhaust, x-pipe and flowmasters. They sound great but are a bit loud for me and I want to put something that is less noisy. Has anyone used the Walkers and will they accomplish my goal of a slighty less noisy ride? If so does anyone need a set of flowmasters cheap?
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor
1969 Dodge Coronet 500
1956 Desoto Hemi
1955 Chrysler C300
Re: Exchange Flowmasters for Walkers on 69 Coronet question
[Re: 68 Sat]
#1407543
03/24/13 12:26 PM
03/24/13 12:26 PM
Posts: 1,960 Kenosha, Wi
GOLDMYN
Kenosha, Wi
WOW! Is that your storage garage? Who does your floors? and by the way, nice car. I'd be proud to own that!
Semper Fi
[Re: 68 Sat]
#1407544
03/24/13 01:29 PM
03/24/13 01:29 PM
Posts: 271 MO, USA
Tom Hand
MO, USA
Dynomax 17747s are 2.25" in and out, offset in, center out, 20" long case and will fit right on IF you have the stock muffler configuration pipes on it. These will outflow the mufflers you have plus they will be significantly quieter at all speeds. Tom
[Re: Kidsixpack]
#1407546
03/24/13 03:25 PM
03/24/13 03:25 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Save some moeny and put on a pair of resonators, that will mellow out the noise and make it so you dont have to replace the existing mufflers. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Tom Hand]
#1407547
03/24/13 04:12 PM
03/24/13 04:12 PM
Posts: 2,554 Maryland
wally426ci
Maryland
I love my Dynomaz super turbos.
[Re: wally426ci]
#1407548
03/24/13 05:11 PM
03/24/13 05:11 PM
68 Sat
Northern NJ
Not my garage but a friends. Thanks for all the input. The flow masters are 13" and the walkers are 22" Long. Otherwise the switch should be seem less.
1956 Desoto Hemi
1955 Chrysler C300
[Re: 68 Sat]
#1407551
03/24/13 08:05 PM
03/24/13 08:05 PM
DaytonaTurbo
Manitoba, Canada
You may want to stay away from a muffler with a center inlet or outlet, depending the muffler's design. A straight through muffler like a dynomax ultra flow, well you're fine there. A dynomax super turbo muffler like this one, if you follow the path of the exhaust you can see all the exhaust has to cross over and under the center tube at one point. Now if there's lots of room in the case, you're okay, but if there's not, you're giving up flow. Maybe not a big deal for a 318 but I would keep it in mind anyway.
