Rear Valance area on '71 Challenger...support brackets? #1407008
03/23/13 10:45 AM
03/23/13 10:45 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hello All,
This morning at the crack of dawn I head out to the garage to install the rear valance for his '71 Challenger R/T. I understand and got the 6 fasteners along the side installed along with the two attach screws that holds the center of the valance on. But, I'm left with these screws that came in the "rear valance kit". Is there a support plate/bracket that's missing or something? The Challenger was taken out of a shop when it was getting painted rather quickly (long story). So I have it here at the house to put it back together for him.
Thanks for insight in advance.
Cheers,
Troy
Houston Mopar Connection Club
Re: Rear Valance area on '71 Challenger... [Re: hemi68charger] #1407009
03/23/13 10:46 AM
03/23/13 10:46 AM
Houston, Tx
Houston, Tx
Rear valance installed. I see two holes on the outboard side of the valance and then 4 holes/nutplates in the frame crossover
Troy
Re: Rear Valance area on '71 Challenger... [Re: hemi68charger] #1407010
03/24/13 10:24 AM
03/24/13 10:24 AM
Houston, Tx
Houston, Tx
Found this on AMD's site investigating this problem. Looks like something I need, no? Right now, the only fastener to the valance is the 3 on either side attach points to the lower quarter panel and the two center fasteners to the crossmember.
Re: Rear Valance area on '71 Challenger... [Re: hemi68charger] #1407011
03/24/13 10:30 AM
03/24/13 10:30 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
There are two brackets that attach to the rear crossmember with 2 bolts and runs down with the shape of the valance and the valance attaches to them on the bottom edge.
EDIT: yes you need those and were the parts I was describing
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Rear Valance area on '71 Challenger... [Re: hemi68charger] #1407012
03/24/13 10:48 AM
03/24/13 10:48 AM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
Troy: Those brackets are for 1970 Challengers only. The center bracket behind where the rear license plate would attach was introduced on 1971 and up rear valences. It is the "replacement" for the two brackets you have picture. The ones in your picture should really have a stud at each end rather than just a round hole, they obviously made them on the cheap, as is the case with most reproduction stuff.
Re: Rear Valance area on '71 Challenger... [Re: m46rat] #1407013
03/24/13 11:08 AM
03/24/13 11:08 AM
Houston, Tx
Houston, Tx
Dwight,
With that said, then '71's don't have anything other than the valance itself? I'll take some more close up pictures of what I have here..
Troy
Re: Rear Valance area on '71 Challenger... [Re: hemi68charger] #1407014
03/24/13 12:34 PM
03/24/13 12:34 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
As said, you don't use the 70 brackets with the 71 & up valance...
Re: Rear Valance area on '71 Challenger... [Re: 1_WILD_RT] #1407015
03/24/13 01:35 PM
03/24/13 01:35 PM
Houston, Tx
Houston, Tx
OK,, too make sure cause I don't wanna have to yank the rear bumper off once I install it. But, there are two sets of vertical nutplates on the rear crossover. If these aren't for any sort of rear valance support bracket, what are they for? Also, I take no credit for the sloppy work on the crossover, hand that one to the bonehead bodyshop my buddy had the car at ( that's a completely long and bad story )
Driver's side
Troy
Re: Rear Valance area on '71 Challenger... [Re: hemi68charger] #1407016
03/24/13 01:35 PM
03/24/13 01:35 PM
Houston, Tx
Houston, Tx
Passenger side..
Troy
Re: Rear Valance area on '71 Challenger... [Re: hemi68charger] #1407017
03/24/13 02:14 PM
03/24/13 02:14 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Driver's side
Troy,
Was this a early 71 SPD?
Tom
68 Charger
70 Cuda
Re: Rear Valance area on '71 Challenger... [Re: hemi68charger] #1407018
03/24/13 02:40 PM
03/24/13 02:40 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The body has the 70 style nut inserts but your using a 71 valance without provisions for the 70 style brackets... It does however have the 71 & up center support.. Your done, put a fork in it...
Re: Rear Valance area on '71 Challenger... [Re: 1_WILD_RT] #1407019
03/24/13 03:12 PM
03/24/13 03:12 PM
Houston, Tx
Houston, Tx
Sorry for being anal, but as we say in the military, "only do a job once" (i.e installing the bumper)...
Thanks everyone.....
Troy
Re: Rear Valance area on '71 Challenger... [Re: hemi68charger] #1407020
03/24/13 03:36 PM
03/24/13 03:36 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Hate to say it but it's a heck of allot easier to install the bumper first, then install the valance...
Re: Rear Valance area on '71 Challenger... [Re: 1_WILD_RT] #1407021
03/24/13 03:42 PM
03/24/13 03:42 PM
Houston, Tx
Houston, Tx
Ahh !!!
Well, I like a challenge..... No pun intended..... If it can be done, I'll try.........
Oh, the learning curve on the E's is steep for this B.....
Troy
Re: Rear Valance area on '71 Challenger... [Re: hemi68charger] #1407022
03/24/13 03:48 PM
03/24/13 03:48 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
It can be done, just gonna have to be a contortionist.... If the ends of the valance have studs & nuts like they originally did pulling & reinstalling the valance shouldn't take more than five minutes...
Re: Rear Valance area on '71 Challenger... [Re: 1_WILD_RT] #1407023
03/24/13 04:46 PM
03/24/13 04:46 PM
Houston, Tx
Houston, Tx
Yeah, you're right... I'd heed your warnings.... If I get the Cheetah valve body installed in the Daytona before day's end, I'll tackle the rear bumper on the Chally.....
Troy
Re: Rear Valance area on '71 Challenger... [Re: hemi68charger] #1407024
03/24/13 05:16 PM
03/24/13 05:16 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I hate iy when that guys right...
Re: Rear Valance area on '71 Challenger... [Re: 1_WILD_RT] #1407025
03/24/13 05:45 PM
03/24/13 05:45 PM
Houston, Tx
Houston, Tx
You had better be, you ARE an E-body owner..... You're supposed to be right.......... Almost done with 'Tona......
Troy
Re: Rear Valance area on '71 Challenger... [Re: hemi68charger] #1407026
03/24/13 06:55 PM
03/24/13 06:55 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
All E body owners are right...& Moparts would be a better place if all you A,B & C body guys just accepted it...
Re: Rear Valance area on '71 Challenger... [Re: 1_WILD_RT] #1407027
03/24/13 07:51 PM
03/24/13 07:51 PM
Houston, Tx
Houston, Tx
Troy
