Re: whats the deal with the 440/540 engine combo
[Re: ahy]
#1406791
03/22/13 10:09 PM
03/22/13 10:09 PM
Posts: 2,177 ill
dennismopar73
ill
Friend has that combo in a 2900# car runs 9.50 no issues, He is going with a set of victor jr full cnc ported heads bigger cam see what it can run this year engine builder,girdle,crete, getting right combo of gears tires run long time
[Re: imfixinmopars426]
#1406792
03/22/13 10:11 PM
03/22/13 10:11 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
You can expect a good, low rpm grunt motor, as I am sure you know. The extra torque down low will definitely be a good thing for such a heavy car. The 540 could run its best shifting as low as 5800 to 6,200 rpm with those heads. That makes it an easy life for the valvetrain. You will also be able to run less bob weight, due to a shorter piston/longrod/long stroke combo. I have run a small port 535 with a tunnelram, shifting it below 6,000. Block grinding for clearance won't be a big deal, just notch the cylinders for rod clearance. You just can't beat a stroker for dual purpose use. The converter will be tight enough for the street, you can run a 3.55 gear and still fly at the track. If it were me, I wouldn't have it any other way!
[Re: belk472]
#1406796
03/23/13 08:23 PM
03/23/13 08:23 PM
Posts: 877 ky
68roadrunner
ky
I have been running that bore and stroke combo for several years but with B1 heads. The stock blocks don't like the horse power I made but should work if use a girdle and don't push it too hard.
wondering what rod you used and if you had the stock block filled. how much hp are you making with that setup
[Re: gregsdart]
#1406797
03/23/13 08:32 PM
03/23/13 08:32 PM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
I just saw that on their website. It is tempting.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
#1406798
03/23/13 08:44 PM
03/23/13 08:44 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If your heads are CNC'd then you will really like the torque... be real here... how often would this hit the track... I'm thinking this is 97% street... if so you will love the torque and low rpm on the street... plus the torque will increase your stall speed some
[Re: belk472]
#1406800
03/24/13 09:59 AM
03/24/13 09:59 AM
Posts: 2,177 ill
dennismopar73
ill
I used a 7.1 rod and filled the block to the bottom of the water pump ports. It made about 880hp and lived 300 passes before splitting #3&4 cylinder walls and the main webbing.
Splitting cyl walls in a filled blocked to the water pump holes may have been the issue,?? Seems to me you have to find away to transfer heat from the cyl away from the cyl, just as a diesel motor has to have happen ,to much crete maybe a bad thing ??? I bought a rotator set from a guy who had the main webbing broken out of the block, sent it to have it checked and re-balance , they found that the balance job was done rather poorly, thus the web cracking issue was resovled, that rotator now has well over 1500 passes on it now, in the same block with no issues ???
[Re: dennismopar73]
#1406801
03/24/13 08:55 PM
03/24/13 08:55 PM
Posts: 576 Texas
ChevyTS
Texas
I had the same problem with the 4.5 stroke. Even with the stud girdle it pulled the mains out. Having said that it did run 9.40 with stage six heads at 2900 pounds for a few weeks.
