Dyno numbers hp vs. stock oil pumps?
#1406547
03/22/13 04:18 PM
03/22/13 04:18 PM
Posts: 250 Iceland
BadMoonRacer
Iceland
Hi folks
Does anyone have dyno numbers comparing horsepower for a high volume versus stock oil pumps for big blocks? I am just curious about this.
Regards
Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials. Icelandic Champion in MC 2007, 2008, 2009 and 2022.
Re: Dyno numbers hp vs. stock oil pumps?
[Re: Dunnuck Racing]
#1406550
03/22/13 05:39 PM
03/22/13 05:39 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Have seen 4+ with stock over hv
JAKES AUTOMOTIVE
#1406551
03/22/13 06:22 PM
03/22/13 06:22 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Kieth, it would be interesting if you would test the new Milodon pump with a stock cast iron cover while you're doing the testing?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#1406552
03/22/13 06:54 PM
03/22/13 06:54 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I would bet the gains would vary wildly. Windage due to amount of oil, viscosity, running oil pressure, restrictions to valve gear, bearing clearances, would all change the numbers from car to car. Dave Dudeck did a lot of work on his Hemi oil system to get some good gains. Can't recall much, except that he had 4 psi pressure at idle, and not much at WOT! (40?)
