Re: Where do I find the power valve on a Holley Carb?
[Re: MNobody]
#140644
10/23/08 09:20 PM
10/23/08 09:20 PM
Posts: 571 Western NC
68Bullit
Western NC
Thanks Gary. It's an AED Holley 750dp. So, either way, it's right there when I take the float bowl off correct?
[Re: dgc333]
#140647
10/24/08 09:42 AM
10/24/08 09:42 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Virtually all Holley 4160, 4150 style carbs have a power valve on the primary side. Some mechanical secondary carbs will have them on the secondary side too.
To only have one on the secondary side would be something some one had been messing with.
Older Holley vac secondary carbs had metering blocks and power valves on the secondarys such as a 3310-1 and 1850-1
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: MNobody]
#140649
10/24/08 10:00 AM
10/24/08 10:00 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
On your 750 its between the primary metering block and the main body.
The reason Holley put PV's on the secondary side of some large double pumpers is because it allows them to reduce the secondary jets about 8 sizes. Without the PV the jets are so large that under heavy braking the fuel in the bowl would push its way up the passages and out the boosters which could stall the engine. The smaller jets minimize the "window" but with the powervalve open, the total fuel metering is the same.
Think about how a PV works. Stays closed until vacuum drops below its rating. The secondary main metering system opens only when the secondaries are open. I cannot think of a situation where you would have the throttle opened far enough that the secondary butterflies open but still have enough manifold vacuum to keep the PV closed.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: MNobody]
#140651
10/24/08 10:17 AM
10/24/08 10:17 AM
CJK440
Ansonia, CT
You will have to obtain a secondary metering block thats machined to accept a PV.
[Re: moparmarks]
#140653
10/24/08 10:30 AM
10/24/08 10:30 AM
Posts: 1,396 Mass
dgc333
Mass
Well you learn something new every day. Didn't realize they put PVs on the secondaries of any vac secondary carbs.
