Where do I find the power valve on a Holley Carb? #140642
10/23/08 09:15 PM
10/23/08 09:15 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
I know this is probably a simple question but I'm gonna check/change my power valve and need to know where to find it. Any pictures or illustrations showing exactly where the pv is?....Thanks
Re: Where do I find the power valve on a Holley Carb? [Re: 68Bullit] #140643
10/23/08 09:19 PM
10/23/08 09:19 PM
MNobody Offline
MNobody  Offline
The power valve screws into to metering block which is the plate that is sandwiched between the float bowl and the main body of the carb. you may have one in the front and one in the back depending on the carb.
Re: Where do I find the power valve on a Holley Carb? [Re: MNobody] #140644
10/23/08 09:20 PM
10/23/08 09:20 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
Thanks Gary. It's an AED Holley 750dp. So, either way, it's right there when I take the float bowl off correct?
Re: Where do I find the power valve on a Holley Carb? [Re: 68Bullit] #140645
10/23/08 09:23 PM
10/23/08 09:23 PM
Kirkland, Washington
Pacnorthcuda Offline
Take off the secondary float bowl. Remove the secondary metering BLOCK. Power valve is on the back side of the block. If you have a metering PLATE (thinner) you don't have a power valve
Re: Where do I find the power valve on a Holley Carb? [Re: Pacnorthcuda] #140646
10/24/08 08:02 AM
10/24/08 08:02 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
Virtually all Holley 4160, 4150 style carbs have a power valve on the primary side. Some mechanical secondary carbs will have them on the secondary side too.
To only have one on the secondary side would be something some one had been messing with.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: Where do I find the power valve on a Holley Carb? [Re: dgc333] #140647
10/24/08 09:42 AM
10/24/08 09:42 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Older Holley vac secondary carbs had metering blocks and power valves on the secondarys such as a 3310-1 and 1850-1
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Where do I find the power valve on a Holley Carb? [Re: Pacnorthcuda] #140648
10/24/08 09:45 AM
10/24/08 09:45 AM
MNobody Offline
MNobody  Offline
Just because it has a secondary metering block instead of a plate,doesn't mean there is a power valve there. My 750 dpl pump mech secondary carb has the power valve blocked off in the back. That said it may not have come that way from the factory but i believe it did.
Re: Where do I find the power valve on a Holley Carb? [Re: MNobody] #140649
10/24/08 10:00 AM
10/24/08 10:00 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
On your 750 its between the primary metering block and the main body.
The reason Holley put PV's on the secondary side of some large double pumpers is because it allows them to reduce the secondary jets about 8 sizes. Without the PV the jets are so large that under heavy braking the fuel in the bowl would push its way up the passages and out the boosters which could stall the engine. The smaller jets minimize the "window" but with the powervalve open, the total fuel metering is the same.
Think about how a PV works. Stays closed until vacuum drops below its rating. The secondary main metering system opens only when the secondaries are open. I cannot think of a situation where you would have the throttle opened far enough that the secondary butterflies open but still have enough manifold vacuum to keep the PV closed.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Where do I find the power valve on a Holley Carb? [Re: CJK440] #140650
10/24/08 10:14 AM
10/24/08 10:14 AM
MNobody Offline
MNobody  Offline
"The reason Holley put PV's on the secondary side of some large double pumpers is because it allows them to reduce the secondary jets about 8 sizes. Without the PV the jets are so large that under heavy braking the fuel in the bowl would push its way up the passages and out the boosters which could stall the engine. The smaller jets minimize the "window"."
Hey that's great info right there, i have that problem on mine under heavy braking it tries to stall, i'm gonna try dropping the jet size and adding a PV to the back. Thanks.
Re: Where do I find the power valve on a Holley Carb? [Re: MNobody] #140651
10/24/08 10:17 AM
10/24/08 10:17 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
You will have to obtain a secondary metering block thats machined to accept a PV.
Re: Where do I find the power valve on a Holley Carb? [Re: CJK440] #140652
10/24/08 10:24 AM
10/24/08 10:24 AM
MNobody Offline
MNobody  Offline
Mine already is, the power valve is blocked off.
Re: Where do I find the power valve on a Holley Carb? [Re: moparmarks] #140653
10/24/08 10:30 AM
10/24/08 10:30 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
Well you learn something new every day. Didn't realize they put PVs on the secondaries of any vac secondary carbs.
Re: Where do I find the power valve on a Holley Carb? [Re: 68Bullit] #140654
10/24/08 02:28 PM
10/24/08 02:28 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
