440 head bolt leaking coolant #1406382
03/21/13 11:33 PM
03/21/13 11:33 PM
wisconsin usa
moretork03 Offline OP
wisconsin usa
ok I have done plenty searches on this subject and it appears there is 2 different opinions on this but I would like too know for sure if any of the internal head bolts enter the water jackets on a 440. I did not use sealant on the bolts and it sure looks like a bolt is leaking a small pool of anti freeze under rocker shaft.
Re: 440 head bolt leaking coolant [Re: moretork03] #1406383
03/22/13 12:13 AM
03/22/13 12:13 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
NONE of the head bolts on a the wedge motor , or hemi, (smallblock??) are WET.
If you have water in the head either the head is cracked or the threaded boss in the block is cracked or has a hole into the coolant passage.
Re: 440 head bolt leaking coolant [Re: JohnRR] #1406384
03/22/13 02:33 AM
03/22/13 02:33 AM
Re: 440 head bolt leaking coolant [Re: JohnRR] #1406385
03/22/13 10:08 AM
03/22/13 10:08 AM
wisconsin usa
wisconsin usa
That is what I thought but the Haynes Chrysler big block rebuild manual states otherwise as does the Chilton's. Both claim to use sealer on the bolt threads. I have a very small amount leaking, level doesn't go down and doesn't show on the stick but I saw a couple drops of green when I pulled the valve cover to check lash.
Re: 440 head bolt leaking coolant [Re: moretork03] #1406386
03/22/13 10:15 AM
03/22/13 10:15 AM
U.S.S.A.
U.S.S.A.
Sorry but both of those books are WRONG .
What heads are you using ?
Re: 440 head bolt leaking coolant [Re: moretork03] #1406387
03/22/13 10:17 AM
03/22/13 10:17 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Are you misinterpreting their saying to use "sealer" as saying to using something like Loctite, a thread locking adhesive?
Re: 440 head bolt leaking coolant [Re: JohnRR] #1406388
03/22/13 10:19 AM
03/22/13 10:19 AM
wisconsin usa
wisconsin usa
915's and the manual says RTV
Re: 440 head bolt leaking coolant [Re: moretork03] #1406389
03/22/13 10:23 AM
03/22/13 10:23 AM
Commando1 Offline
Commando1  Offline
I just checked Haynes and it says Permatex #2. I wouldn't.
Re: 440 head bolt leaking coolant [Re: moretork03] #1406390
03/22/13 10:33 AM
03/22/13 10:33 AM
U.S.S.A.
U.S.S.A.
What head gaskets ? were the heads and block surfaced during rebuild? ... assuming it was rebuilt ???
Otherwise get the engine up to operating temp , release the pressure on the cooling system , pull the valve cover and put a pressure teser on the raditor and pressurize the system , go up a little above 16 , if it's leaking you'll see it them go from there ... did i say the books are WRONG ...
Re: 440 head bolt leaking coolant [Re: JohnRR] #1406391
03/22/13 10:50 AM
03/22/13 10:50 AM
wisconsin usa
wisconsin usa
motor was rebuilt 2 years ago, heads were milled slightly, used the thinner fel pros to keep compression up. changed oil and no sign of coolant in oil, must be very small leak cause like I said just the small drops of green by the bolts. car runs awesome. thanks for advice and will do the test, although am thinking about just sealing the bolt and try it, could it hurt?
Re: 440 head bolt leaking coolant [Re: moretork03] #1406392
03/22/13 10:55 AM
03/22/13 10:55 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
That's what I would try first.
Re: 440 head bolt leaking coolant [Re: pushbutton] #1406393
03/22/13 11:07 AM
03/22/13 11:07 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Pressure test it...And make sure that its not an exhaust manifold/header bolt/stud leaking. Those ARE wet...
MB
Re: 440 head bolt leaking coolant [Re: HPMike] #1406394
03/22/13 11:10 AM
03/22/13 11:10 AM
wisconsin usa
wisconsin usa
definitely internal
Re: 440 head bolt leaking coolant [Re: moretork03] #1406395
03/22/13 11:56 AM
03/22/13 11:56 AM
U.S.S.A.
U.S.S.A.
Yes just put sealant on all the bolts , that will tell you if the head bolt hole is damaged ... because it is not supposed to be in the coolant ... if it still leaks then it's either the head gasket or the head is cracked ...
Good luck
Re: 440 head bolt leaking coolant [Re: moretork03] #1406396
03/22/13 10:47 PM
03/22/13 10:47 PM
which head bolts are leaking, assuming there is more than one on one side?
Re: 440 head bolt leaking coolant [Re: Cab_Burge] #1406397
03/23/13 12:17 AM
03/23/13 12:17 AM
wisconsin usa
wisconsin usa
just one, bottom row second in from rear on left side, did the pressure test - ran it at 18lbs took 20 min to squeeze one drop out, watched it come out right under the head bolt. going to pull the bolt and permatex it tomorrow and re test
Re: 440 head bolt leaking coolant [Re: moretork03] #1406398
03/23/13 09:15 AM
03/23/13 09:15 AM
ill
dennismopar73 Offline
ill
What I have seen is after head milled ,block milled, is the head bolts either stock or even aftermarket tend to be to long, , then add in debris in the bolt hole and you have the makings of cracking the block thru the bolt hole.
It maybe a small crack now, But it will grow!
Temp fix,, is stud it and seal the stud,
Re: 440 head bolt leaking coolant [Re: moretork03] #1406399
03/23/13 10:18 AM
03/23/13 10:18 AM
U.S.S.A.
U.S.S.A.
Do you have studs or bolts holding on your exhaust manifold/header ?
I find it hard to believe 18psi pushing water out from under the head of a fastener that is torqued to what 75ft/lb ... steel against steel ?
Re: 440 head bolt leaking coolant [Re: JohnRR] #1406400
03/23/13 12:14 PM
03/23/13 12:14 PM
wisconsin usa
wisconsin usa
studs holding on headers, had block and heads tested for cracks at build 2 years ago and all checked out good so I don't think its a crack, re-used head bolts so they should be correct length. they are torqued to 70 lbs could it be coming thru gasket some how? How much torque could I put on them?
Re: 440 head bolt leaking coolant [Re: moretork03] #1406401
03/23/13 04:12 PM
03/23/13 04:12 PM
U.S.S.A.
U.S.S.A.
Are the studs the originals or did you replace them ? I think it's coming from a stud , gravity is a funny thing.
But if you think it's coming out of that hole pull the bolt , if it's coming up that hole it will be full of antifreeze.
Rereading this , is it under the valve cover or under the exh. manifold ?
