Damaged aluminum head advice? #1406315
03/21/13 10:36 PM
03/21/13 10:36 PM
Granite City IL.
Jimster70 Offline OP
Granite City IL.
I bought a 6.1 hemi with a damaged head from a broken valve. has anyone had luck with welding and machining the combustion area of these.
Re: Damaged aluminum head advice? [Re: Jimster70] #1406316
03/21/13 11:32 PM
03/21/13 11:32 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I would talk to Brett Miller about that he has good contacts that can fix that. I think his handle on here is w5dart.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Damaged aluminum head advice? [Re: Jimster70] #1406317
03/22/13 12:12 AM
03/22/13 12:12 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Guess you're going to find out the quality of that head when you send it off. Not all "aluminum" heads can be repaired.
Re: Damaged aluminum head advice? [Re: 1967dartgt] #1406318
03/22/13 01:16 AM
03/22/13 01:16 AM
Granite City IL.
Granite City IL.
Re: Damaged aluminum head advice? [Re: Jimster70] #1406319
03/22/13 01:32 AM
03/22/13 01:32 AM
Arizona
Chris'sBarracuda Offline
Arizona
I would think it will be cheaper just to buy another head, new or used..
They're fairly inexpensive from what I've read..
They come complete too.
Chris..
Re: Damaged aluminum head advice? [Re: Chris'sBarracuda] #1406320
03/22/13 05:02 AM
03/22/13 05:02 AM
Granite City IL.
Granite City IL.
800-1200 so far. I called one place that has them advertised for $499 bare and he said he is going to sell the whole lot for $1000 and then tried to sell me a damaged one for the same price.
Re: Damaged aluminum head advice? [Re: Jimster70] #1406321
03/22/13 10:44 AM
03/22/13 10:44 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Larry Demers (engine builder/racer in Iowa) has a guy near him that is really good (except in my case, but a s**t casting W5 was the prob) with cyl head repair. 712-792-4381 (yes...it's a NAPA store, that's the right number).
Re: Damaged aluminum head advice? [Re: J_BODY] #1406322
03/22/13 11:59 AM
03/22/13 11:59 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Repair it,I know 2 people that are real good one is Terry Walters he is the closest to you I will find his # and post it this afternoon.He repaired a head in almost as bad a shape as yours for me. The other is in Tucker Ga he is very good also.Another head is not as cheap as you would think,because it has to be made to match your other head.
PS I think his web site is www.terrywaltersracing.com
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
