Acceptable slick runout diff? #1406191
03/21/13 05:48 PM
03/21/13 05:48 PM
Corvallis,OR
540CUDA Offline OP
super street
540CUDA  Offline OP
super street
Corvallis,OR
I just got a new pair of GY slicks and would like to know how much of a difference would be considered ok. One measures 101.9" the other 102.5". Question is will that cause any real problems? Time to make a phone call to Jegs?
Any help appreciated,
Tony
PRH 540,T-ram,-1's tagged and insured. 9.24et 146.13mph 1.30 60'3300#s
Re: Acceptable slick runout diff? [Re: 540CUDA] #1406192
03/21/13 06:02 PM
03/21/13 06:02 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I usually like to see about 3/8" max difference. When I've had sets that didnt match I usually air the smaller tire up to around 30 psi for about 15 minutes. If you can set it out in the warm sunshine it will help. There have been times I left them aired up for a longer time. Basically your just trying to stretch them out a bit. I guess you could send them back but I've always streched them and they worked fine.
Re: Acceptable slick runout diff? [Re: DavidDean] #1406193
03/21/13 06:30 PM
03/21/13 06:30 PM
Penna
70satelliteguy Offline
Penna
" When I've had sets that didnt match I usually air the smaller tire up to around 30 psi for about 15 minutes. If you can set it out in the warm sunshine it will help. I guess you could send them back but I've always streched them and they worked fine. "
You would be amazed how quick and easy this is to do.
Mike
Re: Acceptable slick runout diff? [Re: 70satelliteguy] #1406194
03/21/13 06:35 PM
03/21/13 06:35 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Mike
I used do that all the time with roundy round cars to get the stagger we wanted. It works a lot better if they haven't been run yet.
Re: Acceptable slick runout diff? [Re: Todd] #1406195
03/21/13 07:02 PM
03/21/13 07:02 PM
Corvallis,OR
540CUDA Offline OP
super street
540CUDA  Offline OP
super street
Corvallis,OR
Thank you very much for the quick replies
Re: Acceptable slick runout diff? [Re: 540CUDA] #1406196
03/21/13 08:39 PM
03/21/13 08:39 PM
I try to ask and make sure the tires I buy are within 1/4 inch of each other in circumference, most race tires are measured at the factory and the circumference is written on the sides of them so it is no big deal for the seller to give you a set like you want Take a look at your tires and see if there marked, I have had sets that are not what thier mark like when inflated I have also done the high pressure throw them in the sun trick, that doesn't always work if there is a large difference between the tires Yours should inflate to what you want
Re: Acceptable slick runout diff? [Re: 540CUDA] #1406197
03/22/13 12:31 PM
03/22/13 12:31 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
goodyear mounted mine at the track and strecthed with air pressure
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Acceptable slick runout diff? [Re: 440lebaron] #1406198
03/24/13 03:36 AM
03/24/13 03:36 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
I get mine direct from Good Year, either at the track or from a dealer as in Roger Krause Racing. I always check the rollout myelf to be sure but in 35 years I have always got rubber that was spot on.
