Lokar kickdown cable #1405647
03/20/13 09:04 PM
03/20/13 09:04 PM
ohio
geol Offline OP
geol  Offline OP
ohio
Anyone use a Lokar kickdown cable and bracket?If so how was it?and was it easy to adjust?
Re: Lokar kickdown cable [Re: geol] #1405648
03/20/13 09:39 PM
03/20/13 09:39 PM
There were a bunch of prior posts regarding Bouchillion & Lokar & there was a concensus on which one was far less problematic & a much better way to go but I didn't retain the info as at the time I didn't think I'd ever be using an aftermarket KD linkage but here's a BTT for ya
Re: Lokar kickdown cable [Re: RapidRobert] #1405649
03/20/13 10:02 PM
03/20/13 10:02 PM
scratchnfotraction Offline
Bouchillon is the better set up. it is based off the stock late model magnum set up.
the throttle lever adaptor has the correct ratio for the mopar throttle valve adjustments with any of the popular carbs.
the lokar is more of a chebby one fits all kinda deal...some have good results and like it.
but after working on the 93 Dak with 5.2 and TV cable set up myself,I like the idea of Bouchillon cable being like what you find on a late model mopar trans..which looks more corret on an old mopar with the late model updated TV set up over mech linkage.
and you can use a stock replacment cable from the mopar dealer if it ever needs repaired in a hurry.
you could just R-O-B-take everything from a late model Dak and get just the throttle adaptor/carb bracket from Bouchillon..maybe?
Re: Lokar kickdown cable [Re: scratchnfotraction] #1405650
03/21/13 03:05 AM
03/21/13 03:05 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
If you use a late model dak the cable is too long & there are different arm's & bellcrank ratios too
John Kunkle helped me figure out the 1st one I built using a 91 Dodge van cable & brackets (they are all the same) I searched out 4 different levers before I got the correct ratio
I have this now & can hook my cruise up too
The parts stores carry the cable
The whole Bouchillion setup is almost $160 when used with their throttle cable bracket
That's cheaper than a trans
Re: Lokar kickdown cable [Re: BulletBob] #1405651
03/21/13 03:34 AM
03/21/13 03:34 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
I used Bouchillion. Highly recommended.
Re: Lokar kickdown cable [Re: Finoke] #1405652
03/21/13 12:46 PM
03/21/13 12:46 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Many say the Bouchillon is the better set up. I've never used one. I have the Lokar throttle and "kick down" cables. They work perfectly fine. Adjustment is easy. My auto shift points are spot on. And it's a cleaner looking setup than Bouchillon. I like that.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Lokar kickdown cable [Re: geol] #1405653
03/21/13 12:58 PM
03/21/13 12:58 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
i've used the lokar set up on many cars and have never had any issues with it. always worked great for me.
i've seen threads here bad mouthing it but who knows if they set it up properly or not. like anything else you never know who or what the installer has done.
i know the leaver i use has always been a shorter abody one. not sure if that makes a difference or not.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Lokar kickdown cable [Re: abodyjoe] #1405654
03/21/13 02:18 PM
03/21/13 02:18 PM
Ontario. Canada
hemidere Offline
hemidere  Offline
Ontario. Canada
I tried the Lokar on my 727 and didn't like it, could never adjust it to my liking, part throttle shifts were either to soon or to late. Couldn't find that sweet spot in between. I just purchased the Bouchillon kit but I have to wait for the snow to melt before I can tell you how well it works...
