Need help loose 05 3500 diesel front end #1405527
03/20/13 04:40 PM
03/20/13 04:40 PM
ME
79machocharger Offline OP
ME
Trying to figure out what's going on with my brothers 2005 dodge dually 3500 cummins. We've replace a bunch of front end parts and it still feels loose in the front end and actually makes a thumping sound that sounds like it's coming from under your feet while your driving it.
-new track bar
-new borgison steering box
-new borgison steering shaft
-couple tie rods
-shocks
Axle joints squeak
Re: Need help loose 05 3500 diesel front end [Re: 79machocharger] #1405528
03/20/13 08:03 PM
03/20/13 08:03 PM
Tidewater, VA
TMCCuda Offline
TMCCuda  Offline
Tidewater, VA
Next thing is ball joints, trailing arm bushings, and steering stabilizer. I think the consensus is that you've got to do everything after you start having problems. I would even look at doing the hub bearings.
The other thing to add is the steering box reinforcement.
Is this a plow truck? Any rust?
1970 Plymouth Barracuda 1994 Ram 1500 4x4 5.2L 2004 Ram 1500 4x4 5.7L Quad Cab
Re: Need help loose 05 3500 diesel front end [Re: TMCCuda] #1405529
03/20/13 10:38 PM
03/20/13 10:38 PM
Sandy, OR
DART67GT Offline
DART67GT  Offline
Sandy, OR
My 2000 Ram 2500 would do that when I accelerated from a stop until I replaced the pitman arm. Now it doesn't thump under the floorboard and it drives down the highway without wandering.
1967 Dodge Dart GT 3.23 sure grip 8.75/727/360 .020 over w/edelbrock heads 2000 Dodge Ram 2500 Quad Cab CTD
Re: Need help loose 05 3500 diesel front end [Re: DART67GT] #1405530
03/20/13 11:24 PM
03/20/13 11:24 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Is it a 4x4? if it is check the front leaf spring, rear bushings, and the pass through at the frame. Do the 05's still use a leaf front? I'm not sure now.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Need help loose 05 3500 diesel front end [Re: hp383] #1405531
03/21/13 12:01 AM
03/21/13 12:01 AM
N
NITROUSN Offline
NITROUSN  Offline
N
They have not used a leaf front since 1993.
Re: Need help loose 05 3500 diesel front end [Re: NITROUSN] #1405532
03/21/13 02:51 AM
03/21/13 02:51 AM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Ah ha! OK I've not owned anything newer than a 93, so I wasn't sure.
Re: Need help loose 05 3500 diesel front end [Re: hp383] #1405533
03/21/13 02:39 PM
03/21/13 02:39 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
A worn sway bar end link will also make a lot of racket when turning and going over bumps.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Need help loose 05 3500 diesel front end [Re: 79machocharger] #1405534
03/21/13 03:39 PM
03/21/13 03:39 PM
Bangor Me
Dodgeman55 Offline
Dodgeman55  Offline
Bangor Me
My 04 diesel has not had that problem but my 04 Intrepid did was a worn swaybar bushing.
1990 Rod Hall Truck #2
78 Lil Red Express
67 Coronet R/T
Re: Need help loose 05 3500 diesel front end [Re: TMCCuda] #1405535
03/27/13 05:30 PM
03/27/13 05:30 PM
ME
ME
It is a plow truck, thanks for the input
Re: Need help loose 05 3500 diesel front end [Re: 79machocharger] #1405536
04/01/13 08:36 PM
04/01/13 08:36 PM
Alexandria, NJ
WayneM Offline
WayneM  Offline
Alexandria, NJ
Plow duty is extremely hard on this combo. If there's more than say 100K, I would proceed with replacing everything. I had to... I even went with a free spin kit to eliminate the POS hub bearings...
2014 Durango R/T
2004 Dodge Ram 3500 SRW SLT short quad Cummins 6 speed
1998 Dodge Durango SLT 5.2
1971 Plymouth Duster-
<<<<<MOPAR SPOKEN HERE>>>>>
Re: Need help loose 05 3500 diesel front end [Re: WayneM] #1405537
04/01/13 08:38 PM
04/01/13 08:38 PM
Alexandria, NJ
WayneM Offline
WayneM  Offline
Alexandria, NJ
'nuther pic.
2014 Durango R/T
Re: Need help loose 05 3500 diesel front end [Re: WayneM] #1405538
04/01/13 09:27 PM
04/01/13 09:27 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
That hub kit is about $1500?
Sheldon
Re: Need help loose 05 3500 diesel front end [Re: RUNCHARGER] #1405539
04/02/13 10:03 AM
04/02/13 10:03 AM
Alexandria, NJ
WayneM Offline
WayneM  Offline
Alexandria, NJ
Yes. That's the spyntec kit. $1550. I found a dealer where I picked up so I paid no tax or shipping. It's a heavy kit lol.
I've since put on the center caps. I'll try to post a picture. I also did moog gresable ball joints and gresable axle u joints. I went from 2 to 10 grease fittings. Lol.
2014 Durango R/T
Re: Need help loose 05 3500 diesel front end [Re: WayneM] #1405540
04/03/13 10:38 AM
04/03/13 10:38 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: Need help loose 05 3500 diesel front end [Re: J_BODY] #1405541
04/03/13 09:39 PM
04/03/13 09:39 PM
RUNCHARGER Offline
RUNCHARGER  Offline
Thanks! I've been spoiling my truck this year.
Sheldon
