Re: 440 with 11.1 comp pistons on pump gas?
[Re: max]
#1405136
03/20/13 10:38 AM
03/20/13 10:38 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
How good is your pump gas I ran 12.2 to 1 on the street with 906 heads on 94 sunoco @ 33/34 deg total timing was fine. But I had a 4000 stall. Where the motor loads is part of the equation as RPM's go up octane requirements lower. (gas burns a constant speed and events speed up) richer mixtures also burn slower than lean! 800 double pumper. The cam was an ultrayne 263/271 duration @ .050 108 lsa installed at 104.5 At the track I needed a 50/50 mix of 110 and 94 to get best runs @ 39 deg total timing (NO VACCUUM ADVANCE) the vacuum advance even on the proper ported vacuum can cause drivability issues at light cruise on a higher compression motor with lower octane fuels. tell us more about what you have we are not clairvoyant. I'm thinking a minimum of 4000 stall and 248 @ .050 duration! Hydraulic or solid in your plans??
[Re: max]
#1405138
03/20/13 10:42 AM
03/20/13 10:42 AM
RapidRobert
google "atkins cycle engine". It was originally in a MRM build decades ago & they used very high compression & a special cam to bleed off enough psi to run regular gas with a phenomenal increase in gas mileage in a chebby truck (dont remember if it was a SB or BB but iirc it was BB). The trade off was a loss of mid/high range power. Something about the cam timing events that gave the benefit of high squeeze but lowered the actual CR so as not to ping & that sounds conflicting but that's what the deal was so yeah check it out & go from there. I'd like to do a 318 mileage build with it
[Re: max]
#1405139
03/20/13 10:44 AM
03/20/13 10:44 AM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
Is it possible to run a 440 with 11.1 pistons and iron open chambered heads on pump gas?
Any ideas what cam to use to bleed off some of the compression to help?
110 octane fuel comes from a pump at my local track
Did you actually measure things and come up with 11:1 ???
Specs of the components you are using ?
I'm sure you could put a big cam in it to bleed off the pressure , but if it's a street engine how well is it going to run at low RPM ???
[Re: 383man]
#1405141
03/20/13 02:48 PM
03/20/13 02:48 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
I run 12.5 with Stealths in my 440.It did have reworked 516s.I can run on pump gas allday.Only time I have any problems is under a real hard load.At the track I run 112 octane.Its driven quite a bit in the summer.A lot depend on the cam and timing also.Mine has 36 degrees all in at about 2200 RPM..If I backed it off I probally would get no clatter.Rocky
Chrysler Firepower
[Re: max]
#1405142
03/20/13 02:59 PM
03/20/13 02:59 PM
Posts: 43,176 Bend,OR USA
Cab_Burge
First of all you need to check the motor over very thoroughly to determine the exact compression ratio, dome volume, cylinder fill volume at TDC, combustion chamber volumes, all eight, head gasket bore and thickness, exact bore and stroke and so on. I would not even attempt to run pump gas in a iron headed stock type 440 with anything more than 10.0 to 1 with 93 octane non ethanol pump fuel With alumunin closed chambers heads and 10.78 to 1 yes, every day IHTHs
[Re: max]
#1405144
03/20/13 03:36 PM
03/20/13 03:36 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
if that's a mopar 484 cam it will not like that low stall and gear. I always thought the TRW's came in stock, six-pack (10.5:1) and the domes were like 12.5:1 The six-pack pistons are flat tops w/ the notches. 6-packs aren't hard to tune, if I can do it anybody can.
[Re: max]
#1405145
03/20/13 04:25 PM
03/20/13 04:25 PM
Dodgem
Ontario, Canada
I'd bet with a fel pro head gasket and no (or very little)head milling he will be at 11 to 11.5 to 1. The dome is not that big after you take into consideration the piston height is about .050 down the hole and the valve trough. I ran those pistons in my 440 906 head motor for one season with a .039 fel pro head gasket and .065 milled off the heads with a big hydraulic cam (the mopar .528 320 duration (272 @ .050??)) and a 4000 stall. Could only run about 33/34 total timing without some race fuel mixed in. with a small cam and that way tight converter he is looking at ping a mopar 484 (degreed in properly) with a 3500 stall (no less than 3000) he may sneak by with 32 degree total timing! That compression is going to want a cam and then the cam will want a converter!!! Has he thought about edelbrock heads will make it more fuel friendly and more pop to boot.
[Re: max]
#1405147
03/20/13 11:39 PM
03/20/13 11:39 PM
Posts: 2,505 God's Country Maryland
GODSCOUNTRY340
There are a few tricks you can do with the heads to lower your compression ratio, and since your engine isn't together these can be done easier. First, use tulip valves in both the intake and exhaust. Second, un-shroud the combustion chambers around both valves out to where the head gasket fire ring is. Third, polish the combustion chambers. You can even, un-shroud where the valves open into the cylinder, again use a used head gasket as a template (to locate where the fire ring is after it's compressed) and go no farther into the cylinder than where the top ring rides. (pic). When assembling the engine use the thickest head gasket you can find.
