cam recommendations #1404929
03/19/13 07:46 PM
03/19/13 07:46 PM
Rancho Cucamonga ca
bill8121 Offline OP
bill8121  Offline OP
Rancho Cucamonga ca
318, 650 edelbrock, 2800 lbs. truck. Stock manifolds, air gap intake, 2" duals, 120 psi all around, j heads 1.88. 2500 stall, 3.23 gears
Just curious if anyone else has a similar set up and what cam works best.
Re: cam recommendations [Re: bill8121] #1404930
03/19/13 07:55 PM
03/19/13 07:55 PM
Renton Washington
Triple Threat Offline
Renton Washington
Comp XE268H
http://www.summitracing.com/parts/cca-20-223-3/overview/make/dodge
Cam might be a touch on the large side, but i believe it allows a little room to grow.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
