A-body door crash bars. #140485
10/23/08 04:16 PM
10/23/08 04:16 PM
Locomotion Offline OP
I'm pretty sure 1971 A-bodies did not have a crash bar in the doors (Duster/Demon). Did they start in 1972 or 1973?
Re: A-body door crash bars. [Re: Locomotion] #140486
10/23/08 05:36 PM
10/23/08 05:36 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
IF they had them it would have been with the redesign in 1973. I know that the door glass in Dart Sports are different for 73, 74, and 75. I have never checked a 76 to see if it is the same as a 75. I don't recall ever seeing a crash bar though...
JB Rhinehart, Realist
A-Body's RULE!
Re: A-body door crash bars. [Re: Locomotion] #140487
10/23/08 05:39 PM
10/23/08 05:39 PM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
My Duster is a '73 model with all the original untouched sheetmetal and it doesn't have crash bars in the doors.
Re: A-body door crash bars. [Re: SuperStocker] #140488
10/23/08 05:41 PM
10/23/08 05:41 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
We cut the ones out of my '76 doors Myron. They weighed 15# per side.
Re: A-body door crash bars. [Re: Locomotion] #140489
10/23/08 05:41 PM
10/23/08 05:41 PM
Anywhere the British Secret Se...
Moonraker Offline
Moonraker  Offline
My 74' Duster(Manufactured 3/73) has them if that helps.
Re: A-body door crash bars. [Re: Moonraker] #140490
10/23/08 05:46 PM
10/23/08 05:46 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Then there is the answer. Probably why the door glass is different from year-to-year also...
A-Body's RULE!
Re: A-body door crash bars. [Re: Locomotion] #140491
10/23/08 05:51 PM
10/23/08 05:51 PM
So far it sounds like 1974 was the first year for the crash bars!
I was curious in case I find a good deal on some doors. My current car started as a '74 and the bars were cut out.
If my other car project takes much longer, I may fix up my current car a bit with early doors having better sheetmetal and glass.
A friend told me that 1973 Dart Sport/Duster door windows were different from later years. Not sure about earlier years.
Thanks!
Re: A-body door crash bars. [Re: Locomotion] #140492
10/23/08 06:34 PM
10/23/08 06:34 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
My '73 Dart Sport doesn't have them.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: A-body door crash bars. [Re: Locomotion] #140493
10/23/08 08:49 PM
10/23/08 08:49 PM
Northwest, Ohio
360DOUG Offline
360DOUG  Offline
Northwest, Ohio
I have a '73 340 Duster and it Does have the crash bars. Built 4/73. Original doors. It may have been a mid year change? I believe the '73 glass is different than the '70-'72 glass. The '73 glass has 5 mounting holes and the previous years only have 4.
Re: A-body door crash bars. [Re: 360DOUG] #140494
10/23/08 09:22 PM
10/23/08 09:22 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Interesting! I tried to put 74 glass in a 73, holes were in different locations. Tried it again from a 75, same thing! Put all three years glass on top of each other and all three had a couple different locations.
A-Body's RULE!
Re: A-body door crash bars. [Re: Rhinodart] #140495
10/23/08 09:38 PM
10/23/08 09:38 PM
lol So '73 may be iffy, if it depends on the build date!
Hopefully if I commit to buy some doors without crash bars, they'll have the windows in them.
Re: A-body door crash bars. [Re: Locomotion] #140496
10/23/08 11:15 PM
10/23/08 11:15 PM
littlestown pa
dustpan man Offline
dustpan man  Offline
littlestown pa
73 was the first year for the crash bars in the door and the glass is a one year only thing for 73 74 to 76 is different
Re: A-body door crash bars. [Re: dustpan man] #140497
10/24/08 02:46 AM
10/24/08 02:46 AM
Park Forest, IL
Park Forest, IL
The term crash "bar" is kind of misleading too. They are really flat plates about 6" wide that run the length of the doors.
Myron, if you want to be real trick find a pair of aluminum doors. I've got a buddy with a pair on a Demon. I'm guessing they would be leftovers from the old P/S cars?
Re: A-body door crash bars. [Re: slantzilla] #140498
10/24/08 07:46 PM
10/24/08 07:46 PM
Medford OR
FrankenScamp Offline
Medford OR
My '73 Scamp has them. kind of a corrigated style plate thing in the door welded to the skin.
Re: A-body door crash bars. [Re: FrankenScamp] #140499
10/24/08 08:17 PM
10/24/08 08:17 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
A lot of NHTSA mandates for "safety equipment" used a Jan 1st date: mandatory headrests & mandatory shoulder belts are 2 examples. Door intrusion beams (more accurately anti-intrusion beams) may have been the same deal.
Some are allegedly removeable, by drilling out the spot-welds and cutting the beam in half to slide it out of the door.
Re: A-body door crash bars. [Re: topside] #140500
10/24/08 08:44 PM
10/24/08 08:44 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
my 73 doors had them until I cut them out they where 17.5 lbs per side.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: A-body door crash bars. [Re: topside] #140501
10/24/08 09:08 PM
10/24/08 09:08 PM
Park Forest, IL
Park Forest, IL
We cut the spot welds, plasma cuttered a slit in the door, and pulled them out whole. The slit was then welded shut.
Re: A-body door crash bars. [Re: slantzilla] #140502
10/25/08 01:08 AM
10/25/08 01:08 AM
Door "beams"....that's it! Just not thinking clearly.
Aluminum doors! Cool! I haven't heard about that "trick" from back then. That would go well with Feather Duster/Dart Lite hoods and trunk lids! I bet they don't have working OEM window and lock mechanisms. But I gotta stay with OEM stuff.
