440 engine identification #1404730
03/19/13 11:04 AM
03/19/13 11:04 AM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
I need help with running the numbers on an engine.(369880-4405 is the number off the block. Is it a HP engine? Thanks!!!
Re: 440 engine identification [Re: roy2345] #1404731
03/19/13 11:18 AM
03/19/13 11:18 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
No way to tell with the info you posted. You need the info from the top pad near the distributor. There is a series of numbers stamped into it. If the HP stamp is present on this pad you have your answer.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 440 engine identification [Re: 70gtx440dana] #1404732
03/19/13 12:17 PM
03/19/13 12:17 PM
dogdays Offline
dogdays  Offline
Come back with ALL the markings on the engine ID pad under the distributor and we'll be able to tell youmore than you dreamed possible about how it was originally built.
One of the neat things about Mopars is engines in a family used the same block and head castings no matter if they were HP or 2-barrel. So all you have told us so far is that it's a 440, by the block casting number.
R.
Re: 440 engine identification [Re: 70gtx440dana] #1404733
03/19/13 02:25 PM
03/19/13 02:25 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
Ok....a guy trying to sell me the engine. I havent seen it yet those just the numbers he gave me but i did tell him to look at the pad when he called me about the numbefs he did find...And Joe Im going be needed your help with parts my friend. Ill email you a list of what ill be needing.
Re: 440 engine identification [Re: roy2345] #1404734
03/19/13 02:30 PM
03/19/13 02:30 PM
Lansing, MI
Lansing, MI
Wil - I sent you a PM. Feel free to contact me for any of your parts needs. Sounds like you have a new project!
Re: 440 engine identification [Re: 70gtx440dana] #1404735
03/19/13 02:34 PM
03/19/13 02:34 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
if its an HP you are after, HP blocks are no different than a standard block. a few internal parts are whats makes the difference.
