Approximate Gas Mileage with fairly stock 440-Six Pack? #140442
10/23/08 01:46 PM
10/23/08 01:46 PM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Hi Guys,
I know the answers are going to be all over the place on this, but about what kind of gas mileage are you guys with 440-Six Packs getting on the street?
I have a fairly stock setup in a Super Bee, but due to numerous sending unit and gauge problems, I'm not too sure what mine is, though I'm guessing it's under 10.
What are you guys with somewhat stock 440-6 setups seeing?
Thanks!
Re: Approximate Gas Mileage with fairly stock 440-Six Pack? [Re: dg_dodge] #140443
10/23/08 02:27 PM
10/23/08 02:27 PM
USA
b54406barrel Offline
USA
Highest ever was 16-17 mpg on hwy, generally 13-15 @ 70-75 cruise. Combined driving about 12 mpg, never checked city only. 3:23's & auto trans. Original carbs & distributor w/vac advance hooked up. Both have been reworked a little, 64 jets in center carb. Headers, very mild cam & lower than stock compression (8.6) and an MSD box working through one set of points. When it was completely stock/original, I recall I could usually get 14 mpg out of it.
Re: Approximate Gas Mileage with fairly stock 440-Six Pack? [Re: dg_dodge] #140444
10/23/08 03:32 PM
10/23/08 03:32 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Got 13 highway, 3.55 rear, 474 cam, 70 cuda.
Re: Approximate Gas Mileage with fairly stock 440-Six Pack? [Re: buildanother] #140445
10/23/08 03:57 PM
10/23/08 03:57 PM
13-14mpg 3.23 gears, .528 MP mechanical, 75mph on the highway.
Re: Approximate Gas Mileage with fairly stock 440-Six Pack? #140446
10/23/08 05:21 PM
10/23/08 05:21 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
My engine is close to stock but bigger valves and cam. 275/530 lift, 354 dana, 4 speed, 60 mph around 14 mph driving normal with 275x60x15 t/a tires
About 8 or so romping on it. which I like to do
Re: Approximate Gas Mileage with fairly stock 440-Six Pack? [Re: dg_dodge] #140447
10/29/08 02:41 AM
10/29/08 02:41 AM
California
cudagee Offline
cudagee  Offline
California
On A good day I get 7 mpg
Re: Approximate Gas Mileage with fairly stock 440-Six Pack? [Re: cudagee] #140448
10/29/08 09:11 AM
10/29/08 09:11 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
This one will get between 16/18 with a 24yr old Purple shaft 284/474 cam and 3.54 rear if I drive it sensibly.
Re: Approximate Gas Mileage with fairly stock 440-Six Pack? [Re: 62maxwgn] #140449
10/29/08 10:56 AM
10/29/08 10:56 AM
NH
Fastback67 Offline
Fastback67  Offline
NH
These numbers seem odd to me ( the numbers reported above)... or maybe not, but a while back, some of the fella's on another site were reporting in on what kind of gas milage they got traveling to the Carlisle 08 show, and most of the 6-Pak guys were reporting high teens and low 20's. Maybe it's just a highway thing with no around town numbers factored in. I don't currently own a 6-Pak myself so I can't speak one way or another.
