Re: Newer MP dist vs. old elec. unit. What gives?
[Re: 68_661charger]
#140428
10/23/08 01:09 PM
10/23/08 01:09 PM
Posts: 515 Dayton, Ohio
65cuda
mopar addict
mopar addict
Dayton, Ohio
maybe u just have too much total. the adj vac thing is misleading. you can't adj how much. u can only adj. how much vac it takes to pull it in. they are pre set. take the # on the the arm and double it thats how much it pulls in when it sees the vac. u adj. it for. some say epoxy a piece of metal on the arm to stop it for the amount you want pulled in.
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers GarysMocars Legendary Dealer
[Re: 65cuda]
#140429
10/23/08 07:54 PM
10/23/08 07:54 PM
Posts: 4,942 WI
Dcuda69
WI
The adj is for when it comes in not how much it adds. Mine put my total way over 50 I still need to modify to limit total w/vac.,for now I run w/o vac.
[Re: Beeware]
#140433
10/24/08 05:37 PM
10/24/08 05:37 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
Out of the box, mine had 28° of mechanical advance that came in by about 3000, and terrible spark scatter. The newer ones have an adjustable plate under the reluctor. There are 2 T-15 Torx screws that you loosen to slide the tabs in the slots open or closed to add or decrease total mechanical advance. I closed mine about 1/2 way and now have 14° of travel. It also causes it to come in earlier. I run 21° initial with 35° by 2800 on my 496" stroker. The spark scatter was hepled greatly by siding a length of 1/2" rubber fuel line over the shaft, cut a long enough that it compresses about 1/8" against the oil pump drive gear when the distributor is tightened down. It acts as a dampener.
I do not run the vacuum advance.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
