Questions about my rings and bearings #1403959
03/17/13 09:12 PM
03/17/13 09:12 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I am gonna buy a stroker kit from a guy for a 500" low deck with Eagle crank, Eagle H-beam rods, and JE flat top pistons.
Main bearings are MS876P which Summit has in stock so I'm good there, $94.95.
Rods call for CB527HD bearings, Summit doesn't have them but they suggest CB527HND which they do have in stock. Are these the same? About $144 for the set.
And last, it calls for JE rings J100008-4375-5 which Summit doesn't sell and they seem expensive through JE at $182....... http://www.jepistons.com/Products/J10008-4375-5.aspx
Any better priced options here? Does Summit offer Rings similar to these?
Starting to wish I'd just stuck with a 440 or a low deck 451.
Re: Questions about my rings and bearings [Re: ProSport] #1403960
03/17/13 09:24 PM
03/17/13 09:24 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Re: Questions about my rings and bearings [Re: ProSport] #1403961
03/17/13 09:33 PM
03/17/13 09:33 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Re: Questions about my rings and bearings [Re: ProSport] #1403962
03/17/13 09:49 PM
03/17/13 09:49 PM
Indy
moparman89 Offline
moparman89  Offline
Indy
H- high perf
N- narrowed
D- dowel hole
The CB527HND is what you want
School of Automotive Machinists Racing
Re: Questions about my rings and bearings [Re: AAR-B4] #1403963
03/17/13 10:56 PM
03/17/13 10:56 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
King high perf bearings on Ebay.
http://www.ebay.com/itm/BBC-CHEVY-HIGH-P...30e&vxp=mtr
Is this just an example of King bearings? Or do these fit my application?
Re: Questions about my rings and bearings [Re: moparman89] #1403964
03/17/13 10:57 PM
03/17/13 10:57 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
H- high perf
N- narrowed
D- dowel hole
Thank you, now I just need to figure out if there's something cheaper out there, such as the King bearings mentioned above.
Re: Questions about my rings and bearings [Re: ProSport] #1403965
03/17/13 11:13 PM
03/17/13 11:13 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I am happy for ya but you may want to wait to get parts untel you have the stroker kit checked out.[not that I think anything is wrong]
Re: Questions about my rings and bearings [Re: ProSport] #1403966
03/17/13 11:14 PM
03/17/13 11:14 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
you will need chamfered main bearings
Re: Questions about my rings and bearings [Re: Clanton] #1403967
03/17/13 11:17 PM
03/17/13 11:17 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Thanks Mike, I'm planning on doing that.
Re: Questions about my rings and bearings [Re: ProSport] #1403968
03/18/13 01:54 PM
03/18/13 01:54 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
So can I use any ring set that is 4.375, 1/16, 1/16, 3/16, or is there more to it than that?
The Mahle kit looks affordable.
Re: Questions about my rings and bearings [Re: ProSport] #1403969
03/18/13 02:38 PM
03/18/13 02:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Sealed Power sells different kits for different needs..............I`d call em.
Re: Questions about my rings and bearings [Re: ProSport] #1403970
03/18/13 02:46 PM
03/18/13 02:46 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
The Mahle kit could possibly also come with .155 radial wall rings........ Good stuff!!!!
Re: Questions about my rings and bearings [Re: 10.90 Racer] #1403971
03/18/13 05:22 PM
03/18/13 05:22 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Napier ring.. That what I just got
Re: Questions about my rings and bearings [Re: ProSport] #1403972
03/18/13 05:57 PM
03/18/13 05:57 PM
I won't use the Mopar rod journal sizes anymore on a stroker motor, B,RB or 426 Hemi If I was you, unless you got a really swinging deal on this kit, I would shop around for the same parts with the BB Chevy(2.200)rod journal sizes and a BB Chevy type long H beam rod with the .990 wrist pin sizes My last and current 400 stoker motor has a forged steel 4.25 stroke Ohio Crankshaft Company crank out of my old Duster 512 C.I. motor, a set of forged steel BB Chevy type PEP 6.700 long H beam rods with a custom set of Diamond pistons with 1.5 MM,1.5 MM and 3.0 MM rings sizes, thems rings is the cats behind Not much drag and lots of power on the dyno and great leak downs, less than 3%, after the dyno testing I used the Federal Mogul # 4094 full narrow groove main bearings and the BB Chevy HP Federal Mogul #7200 CH rod bearings
Re: Questions about my rings and bearings [Re: Thumperdart] #1403973
03/18/13 06:03 PM
03/18/13 06:03 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
X2 I think they will steer you in the rite direction and answer any questions you have on longer mileage rings and bore finish for your ring pack ht and cr,fuel used.
Re: Questions about my rings and bearings [Re: Clanton] #1403974
03/18/13 10:43 PM
03/18/13 10:43 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Cab, I got a good deal on the stroker kit and it is all brand new.
Thanks guys, I will have the engine shop check and measure my parts, then make some calls.
Re: Questions about my rings and bearings [Re: ProSport] #1403975
03/19/13 12:55 PM
03/19/13 12:55 PM
dogdays Offline
dogdays  Offline
So you want to go together on the cheap? I can respect that.
If you are going to file fit the rings, look for a set of 4.380 rings. Rings is rings, you pretty much get what you pay for, but as long as the groove width and depth are right, and the bore is right, they work. And most groove depths are set by a formula determined by diameter.
Some possibilities:
0.020 oversize 460 ford
0.030 oversize 403 olds
0.040 oversize 400 Chrysler
0.050 oversize 440 Chrysler
I'd suggest looking for a Moly set and having the block honed to match.
R.
Re: Questions about my rings and bearings [Re: dogdays] #1403976
03/19/13 03:05 PM
03/19/13 03:05 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
Some possibilities:
R.
Groove depths don't matter........... as long as you have the minimum or more back clearance.......
Re: Questions about my rings and bearings [Re: 10.90 Racer] #1403977
03/19/13 03:30 PM
03/19/13 03:30 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
king high performance and extreme performance rod/main bearings in STD. don't ask me why but summit does not list the extreme performance rod bearing from king they list it from lunati which i'm pretty sure is a king bearing and it's $30 cheaper. imho these bearings are very good and priced well especially with the racer discount.
http://www.summitracing.com/parts/kgb-cr806xpnd
http://www.summitracing.com/parts/kgb-cr806hpnd
http://www.summitracing.com/parts/kgb-mb5116xp
http://www.summitracing.com/parts/lun-mb5116hp
sealed power 4.38 file fit moly ring set 1/16-1/16-3/16
http://www.summitracing.com/parts/slp-r9278065/overview/
Re: Questions about my rings and bearings [Re: jamesc] #1403978
03/19/13 04:15 PM
03/19/13 04:15 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
