727 accumulator spring. needed or not?
#1403894
03/17/13 08:08 PM
03/17/13 08:08 PM
RapidRobert
Street high performance. Installing an already modified VB into an already built 727 for a customer & noticed there was no spring on top of the accumulator piston so I stopped right there. Piston seemed quite aways down in the bore but I'm assuming that is normal. Thank you for your time
Re: 727 accumulator spring. needed or not?
[Re: 383man]
#1403899
03/18/13 02:05 PM
03/18/13 02:05 PM
RapidRobert
It didn't come with a spring when it was dropped off to me & no blocker rod either so unless someone persuades me ASAP to make a blocker rod or add the spring (I have a parts 904 belly up & it's spring looks like a good fit) I'll go ahead & install the VB/pan this afternoon & send er out the door.
[Re: RapidRobert]
#1403900
03/18/13 02:15 PM
03/18/13 02:15 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
Put in the spring , the main purpose is to dampen the trans when it's put into 1st or drive , firmer shifts are a placibo effect from the shift kit ...
[Re: JohnRR]
#1403901
03/18/13 02:34 PM
03/18/13 02:34 PM
RapidRobert
Alright, if the spring will benefit it from dampening when put in drive & ain't going to adversely affect the quality of the shift from the added shift kit I will go ahead & install the spring as this guy does want a firm/crisp shift
[Re: John_Kunkel]
#1403903
03/18/13 05:28 PM
03/18/13 05:28 PM
RapidRobert
John I am heading outside to the garage. Should I USE or NOT USE the spring
[Re: RapidRobert]
#1403904
03/18/13 05:33 PM
03/18/13 05:33 PM
JohnRR
U.S.S.A.
it's YOUR choice .
I have switched from no spring and blocker to putting in the spring after seeing John post about it more times than he cares to remember.
[Re: JohnRR]
#1403906
03/18/13 07:03 PM
03/18/13 07:03 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Thats not the only or main thing it does. Its funny how when ever I read about them they always talk about how it cushions the 1-2 shift before they tell you how the piston buttons the spring side when line press is applied to the bottom when put in gear and applies the rear clutch. Ron
[Re: John_Kunkel]
#1403908
03/18/13 07:42 PM
03/18/13 07:42 PM
So what does the spring do? I would think if you don't have the blocker rod, you should run the spring, but . . .? ? ?
#1403910
03/18/13 08:20 PM
03/18/13 08:20 PM
RapidRobert
It is out the door with no spring/no rod. The customer purchased this built up 727 & a seperate shift kitted VB & I am being paid to install the VB/filter/pan gasket/pan however when I took the pan off to do this 15 minute job I noticed there was no spring in the accumulator so I figured I'd better check in with the pros before I made another move. Thank you all for the interest/info/discussion. Later on I will be doing the 440/727 install for him so if he has a problem with the trans' manners I will deal with it at that point in time.
[Re: BSB67]
#1403911
03/18/13 08:24 PM
03/18/13 08:24 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
That was a low shot! This forum is all about asking questions no matter how much experience one has. He was not 100% sure so he asked the question. That is smart in my book.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#1403913
03/18/13 09:43 PM
03/18/13 09:43 PM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
I think you're missing the point. I have no problem with amateurs asking amateurs and/or professionals questions when someone is working on their stuff or a friends stuff, but he is being paid.
So you pay an electrician to wire a switch in your house, and you must think it is okay that he asks you, or goes on-line to ask non-professionals how to do it.
