Externally balanced 440 into 67 GTX Flexplate question #1403836
03/17/13 05:16 PM
03/17/13 05:16 PM
Tucson, AZ
67G2THEX Offline OP
67G2THEX  Offline OP
Tucson, AZ
I've dropped a 75 440 into my 67 GTX, and just yesterday realized that it's externally balanced compared to earlier 440's. I have the cast crank damper "use on cast crank 440 only", but it's all hooked up to a nuetral balance 727 and torque converter. Besides welding weights onto the torque converter, is there a weighted flexplate that will accomplish the same task? If so, who makes them and part numbers would be appreciated.
Carey
1967 GTX 440 Auto Tribute
1968 Charger 440 Auto
1968 D100 318 Auto Stepside - Daily Driver
1974 Road Runner 318 Auto
1954 Coronet 2dr Hemi Std with O/D
73 Road Runner 360/4spd Sassy Grass - sold
71 Challenger R/T Clone 383 MAG Auto - sold
Re: Externally balanced 440 into 67 GTX Flexplate question [Re: 67G2THEX] #1403837
03/17/13 06:16 PM
03/17/13 06:16 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: Externally balanced 440 into 67 GTX Flexplate question [Re: 67G2THEX] #1403838
03/17/13 06:35 PM
03/17/13 06:35 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
that flex plate above has a cut out that works the same as adding a balance weight to the converter!
Re: Externally balanced 440 into 67 GTX Flexplate question [Re: Dodgem] #1403839
03/17/13 10:53 PM
03/17/13 10:53 PM
Tucson, AZ
67G2THEX Offline OP
67G2THEX  Offline OP
Tucson, AZ
Thanks Guys!!!
