Page 1 of 3 1 2 3
A body with CalTracs/small tire pics #1403597
03/17/13 11:09 AM
03/17/13 11:09 AM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
Post 'em if you gottem! Interested to see how A bodies sit with Cal Tracs mono's or stock leafs and small tires (small meaning like a 275/60 DR, or a 28 X 10-ish). I see Calvert sells their split mono's w/ a 1" drop. I don't like the SS spring look with the rear raised, so looking at the Calvert setup. For budgetary and baseline reasons, probably stick with the factory leafs for now.
Re: A body with CalTracs/small tire pics [Re: Scamp451] #1403598
03/17/13 12:21 PM
03/17/13 12:21 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
my junk.
Re: A body with CalTracs/small tire pics [Re: a493demon] #1403599
03/17/13 01:13 PM
03/17/13 01:13 PM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
Nice, thanks. What size tires, and which leafs? Mine is not going to be mini-tubbed.
Re: A body with CalTracs/small tire pics [Re: Scamp451] #1403600
03/17/13 01:18 PM
03/17/13 01:18 PM
a493demon Offline
a493demon  Offline
it's mini tubed. the tire's are 28x13.5 m/t et streets.has one under mono's.
Re: A body with CalTracs/small tire pics [Re: Scamp451] #1403601
03/17/13 02:00 PM
03/17/13 02:00 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
275/60/15 hoosier drag radial under it in this pic. I have offset leafspring hangers with stock wheel wells. I got the +1 in ride height spring but ended up using 2 inch lowering blocks.
Re: A body with CalTracs/small tire pics [Re: Twin Turbo Mower] #1403602
03/17/13 04:35 PM
03/17/13 04:35 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
zero
Re: A body with CalTracs/small tire pics [Re: Scamp408] #1403603
03/17/13 04:35 PM
03/17/13 04:35 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
+1
Re: A body with CalTracs/small tire pics [Re: Twin Turbo Mower] #1403604
03/17/13 06:34 PM
03/17/13 06:34 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
What backspacing are you using?
Re: A body with CalTracs/small tire pics [Re: hemicop] #1403605
03/17/13 09:04 PM
03/17/13 09:04 PM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
Which one?
Re: A body with CalTracs/small tire pics [Re: Scamp451] #1403606
03/17/13 10:30 PM
03/17/13 10:30 PM
Montgomery, PA
dodge340dart Offline
Montgomery, PA
This is my '69 Dart with the Mono-Leaf springs, 1" lower, and 26"x9" Hoosier slicks. The wheels are 15"x7" with 3.5" backspacing.
Chris
2011 & 2012 Beaver Springs Dragway Outlaw Street Champion 2012 BSD Friday Street Racer Driver of the Year 3-time Jr. Stock Eliminator 2-time Mean Street Eliminator '69 340 Dart 1.500 60ft, 11.359et, 117.08mph
Re: A body with CalTracs/small tire pics [Re: dodge340dart] #1403607
03/17/13 10:39 PM
03/17/13 10:39 PM
Montgomery, PA
Montgomery, PA
Another angle more toward the front.
Chris
Re: A body with CalTracs/small tire pics [Re: dodge340dart] #1403608
03/18/13 07:37 PM
03/18/13 07:37 PM
SO. FLA
W
W2WHO Offline
W2WHO  Offline
W
SO. FLA
275 hoosier radials smallblock power!
Re: A body with CalTracs/small tire pics [Re: W2WHO] #1403609
03/18/13 09:31 PM
03/18/13 09:31 PM
K
KOS Offline
KOS  Offline
K
mine 1" lower
Re: A body with CalTracs/small tire pics [Re: dodge340dart] #1403610
03/18/13 11:11 PM
03/18/13 11:11 PM
michigan woods
imfixinmopars426 Offline
michigan woods
Chris
thanks,your car sits perfect! im getting springs soon,and your pics really helped! is the car a oem white? very neat!...mine is minitubbed,going all caltrac,w/ a indy-1 500".hoping to use a 13.5-14 tire! minitub job is worth it so far.thanks again,mike
Re: A body with CalTracs/small tire pics [Re: imfixinmopars426] #1403611
03/19/13 11:02 AM
03/19/13 11:02 AM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
This is -1" cal-trac mono-leafs with offset mopar hangers..trimmed wheel lip and non modified wheel tubs. 275/60 MT'S
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: A body with CalTracs/small tire pics [Re: 67HEMI] #1403612
03/19/13 09:10 PM
03/19/13 09:10 PM
South Lyon, Michigan
6bblRoadrunner Offline
Cal-Tracs with mono-leafs (-1"). Non-tubbed with 3/4" offset hangers. Hoosier 28 x 11.5 QTP's. I had add a small spacer to the front leaf spring mounts to center the axle in the wheel well. Also had to roll the top of the wheel lip for clearance.
Re: A body with CalTracs/small tire pics [Re: 6bblRoadrunner] #1403613
03/19/13 10:11 PM
03/19/13 10:11 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Very nice car! What motor combo and what does it run?
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: A body with CalTracs/small tire pics [Re: ChrgrCuda] #1403614
03/19/13 10:43 PM
03/19/13 10:43 PM
Thanks. It's a 12:1 340 with W2's, small Hughes solid, 4spd and 4:88's. I haven't run it yet with the W2's. With the bowl worked J heads I had on it it went 11.70's at 117.7 (on worn out M&H's).
Re: A body with CalTracs/small tire pics [Re: 6bblRoadrunner] #1403615
03/20/13 12:19 AM
03/20/13 12:19 AM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
-1 leafs moved in 28x10.5
Re: A body with CalTracs/small tire pics [Re: 6bblRoadrunner] #1403616
03/20/13 12:55 AM
03/20/13 12:55 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Man is that a sharp car, have any more pics?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Page 1 of 3 1 2 3
