manual to power brakes #1403584
03/17/13 10:41 AM
03/17/13 10:41 AM
San Antonio, TX
CurYellowBird Offline OP
San Antonio, TX
I have a 71 roadrunner with manuL drum brakes. Can i buy a brake booster at a parts house and it be a direct bolt on deal? Or do I need a different brake pedal pushrod? I work at oreilllys and can get a setup in a day. Just want to be sure that this is as easy as it seems.
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
Re: manual to power brakes [Re: CurYellowBird] #1403585
03/17/13 12:26 PM
03/17/13 12:26 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
The manual linkage/rod is different than the one for power drum brakes. You will need to find a car that has a power drum brake booster and take the linkage off it.
Re: manual to power brakes [Re: GLR] #1403586
03/17/13 12:33 PM
03/17/13 12:33 PM
San Antonio, TX
San Antonio, TX
Sorry forgot to mention im putting on a-body disc brakes.
Re: manual to power brakes [Re: CurYellowBird] #1403587
03/17/13 12:38 PM
03/17/13 12:38 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
I would suggest getting an adjustable proportioning valve
Re: manual to power brakes [Re: CurYellowBird] #1403588
03/17/13 01:01 PM
03/17/13 01:01 PM
RapidRobert Online content
RapidRobert  Online Content
What GLR said, you need the whole power brake assy off of a donor car. Likely the booster is still good so just replace the M/C (unless the whole assy is fresh from a functioning vehicle) then you're all set at the firewall/under dash part of it (not sure if the brake pedal is the same or not).
