stock 440 rebuild #1403522
03/17/13 02:51 AM
03/17/13 02:51 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Spent the day helping assemble a 0.030" over 440 for a friend today. First time in almost 10 years to put a stock engine with no modifications together.
The crank was only polished, so all stock sized bearings, stock replacement cam, stock replacement pistons (I'll have to get more details on those tomorrow), stock 906 heads, cut 0.010". The heads were 89cc. Tomorrow, we will degree the cam, and see how far below the deck the pistons are.
I will have to get the name of the cam and timing set. The guy just got all the parts from the machine shop. Timing chain has no way to adjust the timing, uses a slot where the cam pin goes? I guess if it is way off, we could drill a hole 180 from the slot and then use a degree bushing?
Used the Superperformance rear main seal kit, and it went in pretty easy. The blue side seals seem a bit stiffer than the orange side seals I had in the 440 source rear main kit (comparison of silicon side seals, fwiw?)
The guy was really impressed with how easy the tapered piston ring compressor is to use.
Re: stock 440 rebuild [Re: 451Mopar] #1403523
03/17/13 11:12 AM
03/17/13 11:12 AM
Yeah I'd degree the cam & see where its at. Eyeball the sprocket & might be nothing to keep you from relocating it (dont forget to redrill the dimple for the dot). Here's some breakin info for you. "breakin secrets" at www.mototuneusa.com (5 minute read). You didn't mention rings & I'd suggest plasma Moly file fit std tension. Set total to 36 with vac adv capped/stat out/bradd penn breakin oil. As you know the breakin is the critical part. good luck!
Re: stock 440 rebuild [Re: RapidRobert] #1403524
03/17/13 11:23 AM
03/17/13 11:23 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Many engines back in the day were stock hi perf engines with a farmers rebuild, better cam, headers and they ran strong. Later on they got the Torker intake and Holley carb. I sure do miss those days of getting a pre 1973 440 powered car out of a field for next to nothing!
Keep old mopars alive.
Re: stock 440 rebuild [Re: 451Mopar] #1403525
03/17/13 11:53 AM
03/17/13 11:53 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
That slotted timing gear is just silly. I don't get it....from a manufacturers perspective, machining that slot is probably more costly than drilling the hole.
Keep posting. I'm enjoying following along.
Re: stock 440 rebuild [Re: RapidRobert] #1403526
03/17/13 06:44 PM
03/17/13 06:44 PM
Australia
big_wedge Offline
big_wedge  Offline
Australia
you could try a 966g key or similar to advance the timing if that chain set is not able to
Re: stock 440 rebuild [Re: 451Mopar] #1403527
03/17/13 08:58 PM
03/17/13 08:58 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
what year was the engine build for ? There aren't any stock replacement pistons for the 68-70 440 piston with a CH of 2.040 , or is it .050 ?
choices are 6pk , 67 or smogger pistons ...
Re: stock 440 rebuild [Re: JohnRR] #1403528
03/17/13 09:27 PM
03/17/13 09:27 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
68 -70, 2.034", plus or minus
Re: stock 440 rebuild [Re: BSB67] #1403529
03/17/13 11:35 PM
03/17/13 11:35 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
If the cam is way off, a double roller timing set with the adjustable crank gear is cheap enough.
http://www.summitracing.com/parts/clo-9-1104/overview/make/dodge
Re: stock 440 rebuild [Re: BSB67] #1403530
03/18/13 12:00 AM
03/18/13 12:00 AM
JohnRR Offline
JohnRR  Offline
thanks , at first I was thinking it was .030 , I have a piston I was going to measure to confirm.
Re: stock 440 rebuild [Re: 451Mopar] #1403531
03/18/13 01:59 AM
03/18/13 01:59 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
The pistons are Sealed Power 350NP, 1.990 compression height. Calculated from specs they should be 0.092" below deck, and when I measured them today, they were 0.092" below deck, so I guess my calculations were right. With the steel shim head gasket (about 5cc) the compression ratio is 8.84:1. The cam and timing set are "Engine Pro" brand. Says made in the USA?
The cam degreed in at 109 intake centerline.
The cam measured (at 0.006") 268/281 duration, at 0.050, it is 208/211 duration. Lift with 1.5 ratio is 0.432"/0.426" lift.
Using the steel shim head gaskets is a first for me, and after putting on one side, noticed the "TOP" stamped in the gasket. Looked at the passenger side we just pit on and sure, it was upside down
I'll ask if it is an issue to have the head hasket reversed, all the oil, cooling, etc holes still lined up, but the embossed part was facing up, when the gasket "TOP" is stamped on the other side. Anyone ever ran an engine that way?
I guess I'll just get another set of gaskets, they are not very expensive.
Re: stock 440 rebuild [Re: 451Mopar] #1403532
03/18/13 02:05 AM
03/18/13 02:05 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I don't think it makes a difference, and most gaskets have the two holes in them for the oil passage to rocker shafts. The gasket can go on and work either way.
Re: stock 440 rebuild [Re: 451Mopar] #1403533
03/18/13 02:27 AM
03/18/13 02:27 AM
JohnRR Offline
JohnRR  Offline
If you haven't run it taking the head off and flipping the gasket shouldn't be an issue unless you glued the gasket onto the block/head , then it won't come off easily and it'll be no good. DAMHIK
Does the owner mind the drop in compression those pistons are giving him ? since there is no quench i guess you could have taken a little more off the heads to bring the compression back up ... especially if he is at altitude ...
Re: stock 440 rebuild [Re: JohnRR] #1403534
03/18/13 03:00 AM
03/18/13 03:00 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
The owner was going the cheap route. He plans to flip the car in a few years. I gave him several recomendations for higher compression pistons, and better cam, timing set, etc.
This is back when I posted about finding out the Sealed Power LW(light weight)2355F piston (773 grams)is only $17.79 more per set than the standard weight (872 grams) 2355F piston (Both are Forged, 2.061 compression height.) The LW2355 also uses the 1/16" ring pack compared to the 5/64" ring pack on the standard 2355F piston.
The owner supplied the steel head gaskets, the gasket kit from the machine shop was the standard Fel-Pro kit. I think he said he has had the gaskets for a long time and thinks they were made by "McCord Gasket." I did verify the oil hole to the rockers was OK, even on the upside down gasket.
Re: stock 440 rebuild [Re: 451Mopar] #1403535
03/21/13 02:36 AM
03/21/13 02:36 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Got a call from the guy we are building the 440 for, and now he wants to install a larger cam with matching valve springs, and a double roller timing chain.
Re: stock 440 rebuild [Re: 451Mopar] #1403536
03/21/13 07:52 AM
03/21/13 07:52 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Have you done a CR calc yet. He might want higher compression too before its done.
Re: stock 440 rebuild [Re: BSB67] #1403537
03/21/13 12:13 PM
03/21/13 12:13 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
People do not like to listen for some reason when you tell them they need/should want more compression. Its the hardest flipping thing to change once the engine is together but they always want to fly with junk pistons.
As far as the slotted timing set, its dumb as hell. I've gotten two slotted turds recently, one was a cloyes and one was a comp. Luckily both timing sets degreed the cam in well, although neither was spot on. The comp set with a comp cam put me in at 104.5, the cam card called for 106 but I was shooting for 104 anyway, so I let it fly.
Re: stock 440 rebuild [Re: GTX MATT] #1403538
03/22/13 10:22 AM
03/22/13 10:22 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I hear you. The guy asked what combination I would use, them goes and gets the cheapest kit anyway.
I told him to get the ZH143CP30 Hypereutectic pistons (2.060 compression height, 5cc valve reliefs), or the LW2355F30 (2.061 ch, 7cc vr).
For a cam, the Lunati 1020704LK (276/284 234/242 @ 0.050, 0.513"/0.533" lift), and an adjustable 3-bolt timing set for the voodoo cam. Even with the 2.06 ch pistons, with 89cc heads and the piston still down 0.022" below deck, compression would only have been 9.75:1. Cutting the block deck 0.020" would give 10.18:1 compression.
