Feel like I'm beating my head against a wall ??????????
#1403485
03/16/13 10:36 PM
03/16/13 10:36 PM
Posts: 1,235 TN
65racer
2009 IHRA World Champion
TN
I have been having a problem with my car for 3 seasons now, I have lost 2 tenth's in the et department, and nothing I have done has got it back, I am at a loss as to why it has slowed down, I just put a fresh engine in the car, as I thought with the cylinder wall clearence my other worn out blocks had, that this might be the problem, but hit a test and tune today, and for the weather, comparing it to the last 3 seasons, it still runs the same, I have been thru the trans, rearend, suspension, and I can't for the life of me, find anything, on the car that is bad, or not working like it should, only thing that has not been changed is the convertor, but it is so deadly, I just can't believe there is something wrong with the convertor, car will print time slips, I just made 2 shots today with it, and both were within .001 out of both lanes, heck last season I changed it over to alky just lookin for something, and it ran the same as with gas, we back to backed it at the track, and no one could believe it did not run any faster on the alky, sooooooo if anyone has a suggestion I am all ears, let's have some input, and see what everyone else thinks about this.
Thanks Dave
Re: Feel like I'm beating my head against a wall ??????????
[Re: hemi-itis]
#1403488
03/16/13 11:12 PM
03/16/13 11:12 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
heard this exact same story one night at that track from a guy I hadn't seen in years. he changed everything.
it was the fuel he was using. he went down on octane and it was right back to where it was. but you tried a fuel change so doesnt sound the same
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: 65racer]
#1403492
03/16/13 11:30 PM
03/16/13 11:30 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Borrow another ignition box.. my car did the same thing.... mine was the 7al box... once I changed it and got the time back I did a A-B-A test and it was the box... so I sent it into MSD and they said it was fine but magically it worked fine after they had it
[Re: hemi-itis]
#1403494
03/16/13 11:42 PM
03/16/13 11:42 PM
Posts: 452 new york usa
pattyboy 572
new york usa
Most of the time its as simple as a wounded amplifier...and an up date..Did an A to B to A found out the one i purchased in the box from a friend was hurt...tech west the only place to send em...pat collins...i to was down about 2 to 3 tenths...till it backfired the front power valve...then for get it .....B is back in car we will see soon?
[Re: pattyboy 572]
#1403496
03/17/13 12:07 AM
03/17/13 12:07 AM
Posts: 1,235 TN
65racer
TN
Dana in the car, all is good there
Tires are fresh, I rolled a new set on recently
Changed fuel, just lookin, no changes with fuel
Car is down 4 mph, and this is 1/8 mile racing
Changed ignition boxes, put a new one on, and also have one from Pat at tech west, no changes with either.
I am at a loss as to what has happened, the engine combo has not changed in the last 6 seasons, except for doing a fresh block every other year, has a fresh one in now, same heads, camshaft, pistons and rods, crank is the same, don't know where to make a move anymore, there is not a nut or bolt on this thing that has not been looked at, the car starts and runs fine, doesn't miss, seems to work just fine, the car is off every where on the race track. 60's 330's finish line, and mph, have tried 3 different carbs, nothing I do makes a difference.
[Re: Dduster]
#1403500
03/17/13 07:59 AM
03/17/13 07:59 AM
Posts: 976 ontario canada
mac56
ontario canada
I know You don't want to think about it being so but I think it's your convertor. My friend had the same problem and he tried everything and finally borrowed a convertor and picked up 3 tenths and his 60 ft times were back where He wanted them. He bought a new convertor after that so He's happy again. Can You borrow anyone's convertor with a car close to your set-up to see??
