AC compressor replacement, 2001 Town & Country. #1402979
03/15/13 10:22 PM
03/15/13 10:22 PM
Walmart parking lot
yorker Offline OP
Drugs are bad
yorker  Offline OP
Drugs are bad
Walmart parking lot
Was told by AC shop my Compressor is seized. Cannot turn the center of clutch by hand. Has current to comp. Does not engage.
There is a TSB on these from lack of oil.
Has rear AC. I can get a NEW DENSO brand Oem Compressor a a good price.
I had a shop quote me the entire job with warranty, not sure what comp they would get for 800.00.
Said they would flush the system, not sure if just the condenser or evaps.
I understand any metal from a bad comp would generally be in the condenser.
The TSB had a whole kit and said check for desicant contimination.
If desicant is in system, the expansion valves must be removed to flush the evaporators.
This is a really big job on the rear AC units. The TSB actually recommended replacing the suction line that runs under the van. This was all in a kit under waranty.
Hope I have no desicant contimination.
I suspect my shop would charge much more to fluch the evaps.
I am really not able to do all of the work, or at least I do not want to.
I can replace the compressor, the dryer , pull a vacum and charge.
I guess, I really need to check for desicant failure because then all that work will have to be performed.
My question is how common is dessicant contimination in these systems?
( SHONEN KNIFE ) MAKING THE WORLD A BETTER PLACE. ONE SONG, ONE CONCERT AT A TIME FOR OVER 36 YEARS!!
https://www.youtube.com/user/SHONENKNIFETV
Re: AC compressor replacement, 2001 Town & Country. [Re: yorker] #1402980
03/15/13 11:25 PM
03/15/13 11:25 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The dessicant and filtering is in the reciver drier or suction accumulator depending on the type of system. Your system should use a drier with an exspansion valve as the accumulator system uses an orfice setup. Always replace the drier and flush everything else you are not replacing. Check the exspansion valve real close also for any contamination that could have gotten to it. If in question I always replace the exspansion valve. And dont forget to add the proper amout of the right oil to the system. Ron
