Driveshaft Length Help (and Slip Yoke)UPDATE #1402889
03/15/13 06:05 PM
03/15/13 06:05 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Just got my trans back in and while putting my DS back in I only have a 1/2" of room until it bottoms out. This is with the car on jackstands but on axle and control arms. Is This enough play?
Re: Driveshaft Length Help With Caltracs [Re: Scamp408] #1402890
03/15/13 06:24 PM
03/15/13 06:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've always run 3/4" as the spec.... 1/2" might be on
the close side... would hate to see you bottom out
and bust up stuff
Re: Driveshaft Length Help With Caltracs [Re: MR_P_BODY] #1402891
03/15/13 06:29 PM
03/15/13 06:29 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I ran it like this for years but thought 1/2 was too close.
Re: Driveshaft Length Help With Caltracs [Re: Scamp408] #1402892
03/15/13 06:36 PM
03/15/13 06:36 PM
Renton Washington
Triple Threat Offline
Renton Washington
That's pretty tight, if you let the rear end hang it will probably get even tighter.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Driveshaft Length Help With Caltracs [Re: Triple Threat] #1402893
03/15/13 06:40 PM
03/15/13 06:40 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I cant tell what it bottoming out on either. I just freshen up trans and the stator sealling rings were shot .
Re: Driveshaft Length Help With Caltracs [Re: Scamp408] #1402894
03/15/13 06:42 PM
03/15/13 06:42 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
On SS springs and 1 year on monos.
Re: Driveshaft Length Help With Caltracs [Re: Scamp408] #1402895
03/15/13 09:38 PM
03/15/13 09:38 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
So Mr P I should look for 3/4? I will get it on the ground and ck it again and also ck the pinion angle to make sure nuttin moved.
Re: Driveshaft Length Help With Caltracs [Re: Scamp408] #1402896
03/15/13 09:46 PM
03/15/13 09:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The Munroe trans book says 3/4"... so thats what I
have been using for years
Re: Driveshaft Length Help With Caltracs [Re: MR_P_BODY] #1402897
03/16/13 08:17 AM
03/16/13 08:17 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
You could try shimming out the front spring hangers 1/4 inch. If you have the room for the tyre
Re: Driveshaft Length Help With Caltracs [Re: Tig] #1402898
03/16/13 09:36 AM
03/16/13 09:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
This is what I would do... in most cases it centers
the tire better in the wheel well
Re: Driveshaft Length Help With Caltracs [Re: MR_P_BODY] #1402899
03/16/13 11:22 AM
03/16/13 11:22 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Already have the axle 1in back but thanks. I think the yoke is the problem. I have a output shaft for a 727 handy and it only slides in so far,it doesnt bottom out. I also have an old mopar yoke and it bottoms out on both extra shaft and trans.I looked inside yoke but cant see any damage but it does fit tighter than the mopar one.
Re: Driveshaft Length Help With Caltracs [Re: Scamp408] #1402900
03/16/13 11:34 AM
03/16/13 11:34 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
not saying this is right.. but I cut a half inch of a yoke one time and it worked fine. the old chopsaw did the trick. was this a bad idea
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Driveshaft Length Help With Caltracs [Re: Scamp408] #1402901
03/16/13 12:19 PM
03/16/13 12:19 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mine`s a bit over a 1/2" and has been 4 years..........
Re: Driveshaft Length Help With Caltracs [Re: Scamp408] #1402902
03/17/13 01:41 PM
03/17/13 01:41 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
The splines arent twisted but down inside some may look weird I may have to rethink this all over because of this I may be to short.
Re: Driveshaft Length Help With Caltracs [Re: Scamp408] #1402903
03/17/13 04:24 PM
03/17/13 04:24 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Just got a new ds from dynotech. It measures 1.5 slip yoke clearance. Gave him all the measures.
Re: Driveshaft Length Help With Caltracs [Re: mopar dave] #1402904
03/17/13 04:32 PM
03/17/13 04:32 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Well im gunna order a new slip yoke and go from there. Now correct me if I am wrong should I push yoke in till it gently stops than pull out 3/4 to ? inches. I have a small seal not the boot.
Re: Driveshaft Length Help With Caltracs [Re: mopar dave] #1402905
03/17/13 04:36 PM
03/17/13 04:36 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
1.5" is too much. Slip yoke clearance should measure 3/4"-1".
Re: Driveshaft Length Help With Caltracs [Re: DoctorDiff] #1402906
03/17/13 04:48 PM
03/17/13 04:48 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Hey doc how much for a good slip yoke
Re: Driveshaft Length Help With Caltracs [Re: DoctorDiff] #1402907
03/17/13 04:55 PM
03/17/13 04:55 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I think the tail shaft sticking out the case 1 1/4" may be the reason for this. The caltrac bars hold the dana from rotating so wheres the problem?
Re: Driveshaft Length Help With Caltracs [Re: Scamp408] #1402908
03/17/13 05:12 PM
03/17/13 05:12 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
A forged steel 1350 727/833 slip yoke is $179
A forged steel 1350 pinion yoke is $70
