Wiring up a RoadRunner #1402863
03/15/13 05:18 PM
03/15/13 05:18 PM
Charleston, SC
safaritow Offline OP
Charleston, SC
I'm stuck, I'm rewiring a 70 Roadrunner and found two dark blue w/ white tracers and two light green wires both colors joined with terminals they come down under the dash on the drivers side kick panel. I don't know were they go or what they hook up to. Please help.
Re: Wiring up a RoadRunner [Re: safaritow] #1402864
03/15/13 05:21 PM
03/15/13 05:21 PM
If no one chimes in with a direct answer you might checkout the wiring diagrams at www.mymopar.com
Re: Wiring up a RoadRunner [Re: safaritow] #1402865
03/15/13 05:35 PM
03/15/13 05:35 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Not sure without some photos....is this the original wire harness for the 70 Road Runner? If not, it sounds like you are talking about the wires for the 70 Charger hidden headlight system which is only found in the 70 Charger harness. See photo below for the Charger only green and blue with white tracer wires (top of photo). You can tape them up for your application as you do not need them.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Wiring up a RoadRunner [Re: 70gtx440dana] #1402866
03/15/13 06:02 PM
03/15/13 06:02 PM
Charleston, SC
Charleston, SC
Yep that's them awesome, thank you. You don't know where to plug in the console lights into the harness at do you?
Re: Wiring up a RoadRunner [Re: safaritow] #1402867
03/15/13 07:54 PM
03/15/13 07:54 PM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
Yeah - you plug those into their receiving connector.
Re: Wiring up a RoadRunner [Re: WyleECoyote] #1402868
03/15/13 09:17 PM
03/15/13 09:17 PM
California
mickm Offline
mickm  Offline
California
don'cha just love this forum, a wealth of experience and knowledge, right at your finger tips!
Re: Wiring up a RoadRunner [Re: safaritow] #1402869
03/15/13 10:08 PM
03/15/13 10:08 PM
Lansing, MI
Lansing, MI
There is a small pigtail harness in the console. From the console there is a harness that runs over to the wire channel at the drivers door....the wires then run forward to the kick panel area. The connector should tie in with the dome lamp wiring. I think it is the connector that will be closest to the bright switch connector on the floor. See photo below.....top right.
Re: Wiring up a RoadRunner [Re: 70gtx440dana] #1402870
03/15/13 10:34 PM
03/15/13 10:34 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
I think this is what you're looking for.
Re: Wiring up a RoadRunner [Re: thehemikid] #1402871
03/15/13 10:36 PM
03/15/13 10:36 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Then out of the wire channel...
