70 Cuda Rocker Moldings - Hardware #1402673
03/15/13 08:55 AM
03/15/13 08:55 AM
SE PA
Paul G Offline OP
Paul G  Offline OP
SE PA
Does anyone know what hardware is needed to attach the 70 Cuda rocker moldings (Gill style) and where to get the fasteners? could not find it in the parts books.
Paul
Re: 70 Cuda Rocker Moldings - Hardware [Re: Paul G] #1402674
03/15/13 08:59 AM
03/15/13 08:59 AM
MI, Livingston
P
plymth70 Offline
plymth70  Offline
P
MI, Livingston
They use screws only, no clips
Re: 70 Cuda Rocker Moldings - Hardware [Re: plymth70] #1402675
03/15/13 10:17 AM
03/15/13 10:17 AM
New York, Chautauqua county
mightycuda Offline
mightycuda  Offline
They require 9 per side and R/T specialties has the correct screws.
Re: 70 Cuda Rocker Moldings - Hardware [Re: mightycuda] #1402676
03/15/13 11:20 AM
03/15/13 11:20 AM
California
biggE Offline
biggE  Offline
California
The original screws were not threaded completly. The unthreaded portion stopped the screws from going into the rocker moulding to far and breaking the area that the hole was in. The repos are threaded all the way to the head.
Re: 70 Cuda Rocker Moldings - Hardware [Re: Paul G] #1402677
03/15/13 06:31 PM
03/15/13 06:31 PM
SE PA
Paul G Offline OP
Paul G  Offline OP
SE PA
Thanks everyone for the quick responses!!!!!!!!!!!!
Re: 70 Cuda Rocker Moldings - Hardware [Re: Paul G] #1402678
03/15/13 09:17 PM
03/15/13 09:17 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Here's a pic of some NOS pieces...Courtesy of m46rat from a previous thread years ago...Hey Dwight do you even have this pic anymore ???
Re: 70 Cuda Rocker Moldings - Hardware [Re: screamindriver] #1402679
03/15/13 10:26 PM
03/15/13 10:26 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
I bought a set from M46 and they bottomed out on the shouldered portion before they secured my original gills. The originals on my friends survior were threaded completely. Maybe there was more than one OEM supplier of the moldings?
Re: 70 Cuda Rocker Moldings - Hardware [Re: 70440+6bbl] #1402680
03/17/13 09:52 PM
03/17/13 09:52 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
The half inch long threaded sealed portion of each screw is what sticks out below the bottom of each rocker moulding hole and anchors into the rocker panel. I have heard back from a lot of the people that I have sold these to, telling me that they fit great. I have not had any complaints about these. If anything, the sealed portion, which can vary in thickness from screw to screw, is more often than not, a little wider than the rocker moulding hole, so when it is screwed in, fits very snug, although none of the sealed portion should be left inside the rocker moulding hole once the screw is secured into the rocker panel.
I have seen other original screws used to secure these rocker mouldings that do not have the shoulder on them, they are completely threaded. The ones I have seen are always shorter than the ones shown in the picture, for some reason. That would mean less threads from each screw attaching to the rocker panel.
