Re: 11 inch drum ?
[Re: skicker]
#1402552
03/15/13 11:35 AM
03/15/13 11:35 AM
Posts: 3,472 Lubbock, TX
Erics5th
UsedtobeSatellite6
UsedtobeSatellite6
Lubbock, TX
11" drum/backing plates from an 8 1/4" rear will also work on an 8 3/4.
Eric
Re: 11 inch drum ?
[Re: skicker]
#1402554
03/15/13 01:08 PM
03/15/13 01:08 PM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
As long as you keep the correct drums with the correct backing plates they will interchange.
As long as your not putting them on an A body 8-3/4. 8-1/4, 8-3/4, 9-1/4, DANA, all should interchange. I've even used F body 7-1/4 rear brakes on an 8-3/4.
Re: 11 inch drum ?
[Re: coro500net]
#1402559
03/15/13 09:58 PM
03/15/13 09:58 PM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
If they were together on a C body and you change the bolt pattern on the A body to bbp you shouldn't have any issues.
...FAFO...
Re: 11 inch drum ?
[Re: nomore65BelvJim]
#1402561
03/16/13 12:28 AM
03/16/13 12:28 AM
Posts: 2,225 Silsbee,Tx
-Cuda
Silsbee,Tx
So a 7-1/4 setup from an ebody would work on a 8-3/4? If so I need to pull the brake setup before the junk man hauls it off.
