360 truck build #1402169
03/13/13 10:16 PM
03/13/13 10:16 PM
mesa arizona
moturbopar Offline OP
mesa arizona
Hi all, 318 in my 2wd 84 d-150 took a dump, so I put together this.
73 360
.30 over h405cp pistons,
.026 head gaskets, 9-1 compression
Un-cracked magnum heads, some port work!!!
crane energizer 272 (old school cam) specs are
216 at .050 in and exhaust 110lc .484 lift with 1.6 rockers
RPM air-gap, summit 750 vac-sec carb
1 5/8 long tube headers, 2.5" y pipe, into a single 3"exhaust.
Rebuilt 904 non lock up, with 2300 to 2500 stall
3.55 gears. Thinking it will make for a peppy engine, that doesn't kill fuel economy. So Im thinking 300 to 325 hp and maybe 400ftlb. So Think this is a fair estimate. It be even better if It would break into the 14s!
Re: 360 truck build [Re: moturbopar] #1402170
03/13/13 10:24 PM
03/13/13 10:24 PM
Paris, Tx
mopartruckguy Offline
Paris, Tx
Sounds like a similar offering from Mopar performance a few years back in a crate motor they claimed made, I believe, around 360hp not sure on torque. I would think that 325hp would not be an unrealistic number.
Re: 360 truck build [Re: mopartruckguy] #1402171
03/13/13 11:04 PM
03/13/13 11:04 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Seems like really low lift... those Magnum heads don't make peak flow till .500 or better, and you're not even getting to .500 If it's not too late, and you're still in the shopping stage, I'd consider a different cam, same duration but more lift, should help with torque by allowing more airflow.
**Photobucket sucks**
Re: 360 truck build [Re: 70Cuda383] #1402172
03/13/13 11:12 PM
03/13/13 11:12 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
if i'm reading that right, the 1.6 rockers will make that cam a .774 lift?
Re: 360 truck build [Re: Golden-Arm] #1402173
03/13/13 11:16 PM
03/13/13 11:16 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
.484 with the 1.6 not .484 lobe lift.
Re: 360 truck build [Re: HotRodDave] #1402174
03/13/13 11:21 PM
03/13/13 11:21 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i was going to base the cam off a 1.5 rocker actually, making for a .532 with a 1.6. not sure what he based the .484 off of. i'd run a whiplash, spec'ed to the resto of the build myself.
Re: 360 truck build [Re: Golden-Arm] #1402175
03/14/13 12:50 PM
03/14/13 12:50 PM
mesa arizona
mesa arizona
Sorry. the lift. is .454 with 1.5 ratio rockers. I know the cam is a little weak, but I got it for a good deal. The plan is to put a hyd roller, and roller valve train, with next years tax refund. Just didn't have $$. I still think this cam will do ok, and will be easy on the pretty much stock magnum valve train. Thanks guys
Re: 360 truck build [Re: moturbopar] #1402176
03/14/13 02:42 PM
03/14/13 02:42 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
73 360
I built a 360 many years ago that used the same Crane cam,j heads(home ported),RPM intake,headers,904 lockup trans,stock slant six converter,gearing was3.23 ish. I installed it in an 87 Dodge 150 2wd long bed for a daily driver(4000lbs? with me). Got great mileage and drove very nice with enough grunt to smoke the tires from 40MPH rolls. It ran 14.20's smoking street tires @100-102mph without tuning . It ran better with smaller carbs than the 750 holley.It was done @5200rpm so it's not hp build but for a truck its not bad. I think you'll be ok with that combo. Put the same engine in my Duster ran low 12's @110mph shifting @ 5200rpm.
Re: 360 truck build [Re: goldmember] #1402177
03/14/13 05:15 PM
03/14/13 05:15 PM
mesa arizona
mesa arizona
That's what I like to hear! Id be happy with 14s in a truck!
I do have comp xe268 available to me. The heads and springs are good to .580 lift. the biggest problem is the stock stamped rocker arms, not sure how much they can handle.
Re: 360 truck build [Re: moturbopar] #1402178
03/14/13 07:44 PM
03/14/13 07:44 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I'd stick with the crane cam. I have no idea what your springs are but I'd guess the valves are longer than stock or the guides are shortened to get that much room,with this cam you don't need anything trick at all. 110-130seat 275-300open is plenty. Stock rockers will not be an issue with those numbers. I'd expect with good tune and traction mid 13's would be a breeze.
Re: 360 truck build [Re: moturbopar] #1402179
03/14/13 09:44 PM
03/14/13 09:44 PM
Lehigh Acres, Florida
rickstershemi Offline
Use it you will love it.....ran a xe268 in our stock la 360 with stock springs and rockers.....it was a screamer
Rickster
Re: 360 truck build [Re: rickstershemi] #1402180
03/14/13 11:13 PM
03/14/13 11:13 PM
mesa arizona
mesa arizona
The guides have been cut, and Im using hughes retainers and 1110 springs.
