70-71 E body rocker panels
#140212
10/22/08 09:57 PM
10/22/08 09:57 PM
Can someone chime in and let me know if a complete B body rocker panel might fit a 70-71 E body application. Any help greatly appreciated, Thanks in advance.
Re: 70-71 E body rocker panels
#140213
10/23/08 01:01 AM
10/23/08 01:01 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Nope. Way different. Also 70E rockers are different than 71E rockers and Challengers are 2" longer than Cudas.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#140214
10/23/08 01:04 AM
10/23/08 01:04 AM
Posts: 27,467 So Cal
autoxcuda
So Cal
In the way they are attached or in the appearance?? Both years are the wide style.
71 Cuda's are thin and Gran Coupes are wide with ribs. Don't know if 71 and 70 Gran Coupes share the same rocker molding.
I always thought 70 and 71 Challengers rocker moldings were the same. I have an NOS pair for my 71 and a couple of used ones. Look the same, but they could obviously be from the same year of course.
[Re: autoxcuda]
#140215
10/23/08 02:19 AM
10/23/08 02:19 AM
moparmarks
I thought he was talking about actual rocker panels, not moldings.
[Re: moparmarks]
#140216
10/23/08 02:30 AM
10/23/08 02:30 AM
autoxcuda
So Cal
Duh, you're right. My bad. Don't replace a lot of complete rockers here in So Cal. Went right over my head.
[Re: moparmarks]
#140217
10/23/08 08:17 AM
10/23/08 08:17 AM
Posts: 2,304 WI
RestoRick
WI
Mark, How do the 70E's differ?
Thanks, Rick
[Re: RestoRick]
#140218
10/23/08 08:21 AM
10/23/08 08:21 AM
moparmarks
Thanks, Rick
On the inside, there is no ledge for the floor pans to lay on like on the 71/4's.
[Re: RestoRick]
#140220
10/23/08 10:21 AM
10/23/08 10:21 AM
moparmarks
ok yes.. that's actually a separate part I'd call the "inner rocker". but the outer rocker skin is the same, correct?
Thanks, Rick
Yes the outter skins are the same for all years.
[Re: moparmarks]
#140221
10/23/08 11:09 PM
10/23/08 11:09 PM
Thanks to all who cleared the rocker panel issue up for me. So what I'm looking for is a good straight & solid drivers side rocker panel from a 71-74 Cuda. I need the side cowl area also, up to the windshield post and firewall. Any leads out there would be appreciated! Again Thanks to all who responded to my original post.
