2005 Neon 5 Speed ??? Linkage broken?? #1401963
03/13/13 01:53 PM
03/13/13 01:53 PM
Pennsylvania
scannman70 Offline OP
Pennsylvania
2005 Neon 5 speed. friend of mine at college in Okeechobee Florida. Stopped for gas this morning, shut car off, got gas, started back up, she said her shifter is like "there is nothing there" Can't find any gears.
I am in PA or I would just crawl under it, I am thinking something fell off the linkage.
Any one have this problem?? Got any Ideas. She is pretty much on her own down there. and needs to get this car fixed.
Thank you
Re: 2005 Neon 5 Speed ??? Linkage broken?? [Re: scannman70] #1401964
03/13/13 02:40 PM
03/13/13 02:40 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
Possibly shift linkage bushings. aftermarket fix
Re: 2005 Neon 5 Speed ??? Linkage broken?? [Re: 71charger] #1401965
03/13/13 03:22 PM
03/13/13 03:22 PM
Northeast MA
Charger446 Offline
Charger446  Offline
Northeast MA
Agreed, had the same issue on my 97 Plymouth Breeze, from what I remember, it was an easy fix
Re: 2005 Neon 5 Speed ??? Linkage broken?? [Re: scannman70] #1401966
03/13/13 09:28 PM
03/13/13 09:28 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I've used them, they just pop in. Also you have the same thing on the shifter. You will get 4 when you order them.
Re: 2005 Neon 5 Speed ??? Linkage broken?? [Re: 71birdJ68] #1401967
03/13/13 09:43 PM
03/13/13 09:43 PM
IN
ahy Offline
ahy  Offline
IN
Me too
Re: 2005 Neon 5 Speed ??? Linkage broken?? [Re: ahy] #1401968
03/13/13 09:47 PM
03/13/13 09:47 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Getting to them can be a little bit of a pain. Sometimes the battery and tray have to come out.
Master, again and still
Re: 2005 Neon 5 Speed ??? Linkage broken?? [Re: DaveRS23] #1401969
03/14/13 10:39 AM
03/14/13 10:39 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
The OEM bushings on my 2000 lasted 3 or 4 years. Mopar doesn't sell just the bushings, only the complete cable assembly for $130 (price from 10 years ago, maybe more now). Booger Bushings, as linked to above, are $22 delivered. Mine BBs lasted 9 or 10 years but eventually failed two months ago. So for just another $22, I'm back up and running.
The hardest part changing the two on the shifter end is getting the console out. Yank the park brake lever up as far as it will go and force, repete, FORCE, the console up and out. It may feel like it will break but they will bend quite a bit. The shifter pins where the bushing clips on are horizonal, so when they go bad, the cable end falls off and you have zero shift. This is what happened to her Neon. With the console out, the cable can be moved by hand to get it in gear and move the car. The shift knob comes off by pushing down and turning it clockwise 1/4 turn.
The trans end bushing pins are verticle so when the bushing fails, the the cable end stays on and will still shift, although with slop. Yes, remove the battery and tray to get to them.
A few short lengths of 3/16" fuel line slipped over the pins to take a bit of the slop out and a loosely fitted tie wrap will hold the cable ends on till the Booger Bushings are delivered.
Change all 4 bushings as the others aren't too far behind.
Re: 2005 Neon 5 Speed ??? Linkage broken?? [Re: B5 Bee] #1401970
03/14/13 10:53 AM
03/14/13 10:53 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
MAKE that bushing out of a wood dowel !
Re: 2005 Neon 5 Speed ??? Linkage broken?? [Re: B5 Bee] #1401971
03/14/13 09:07 PM
03/14/13 09:07 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Changing the bushings under the shifter is much more of a pain than changing the ones under the hood. So I would start with just changing the ones under the hood, which is where the majority of failures occur.
I have changed a dozen or more ones under the hood, but have never changed the ones under the shifter.
Re: 2005 Neon 5 Speed ??? Linkage broken?? [Re: DaveRS23] #1401972
03/14/13 11:08 PM
03/14/13 11:08 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I changed mine under the shifter, just pull the console up. I also made one out of wood but they don't last long.
Re: 2005 Neon 5 Speed ??? Linkage broken?? [Re: 71birdJ68] #1401973
03/14/13 11:41 PM
03/14/13 11:41 PM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
I run the rage-tek shifter bushings. Same kind of money as boogers, but they are easier to install and last longer.
Re: 2005 Neon 5 Speed ??? Linkage broken?? [Re: rallye73] #1401974
03/15/13 11:23 PM
03/15/13 11:23 PM
541 slobovia
A990 Online content
A990  Online Content
541 slobovia
gotta link?
Re: 2005 Neon 5 Speed ??? Linkage broken?? [Re: A990] #1401975
03/16/13 11:41 AM
03/16/13 11:41 AM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
gotta link?
rage-tek.com
Re: 2005 Neon 5 Speed ??? Linkage broken?? [Re: rallye73] #1401976
03/16/13 02:56 PM
03/16/13 02:56 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
first I've ever heard of rage-tek, but my Neon's almost 9 years old, so, I think I'm going to order a set and install them as preventative maintenance
Re: 2005 Neon 5 Speed ??? Linkage broken?? [Re: rallye73] #1401977
03/16/13 06:06 PM
03/16/13 06:06 PM
541 slobovia
A990 Online content
A990  Online Content
541 slobovia
tink you beddy much!
Re: 2005 Neon 5 Speed ??? Linkage broken?? [Re: A990] #1401978
03/16/13 08:55 PM
03/16/13 08:55 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
How can rage-tek be easier to install than booger bushings? They just push on, 5-10 seconds each. 99% of the work is to the R&R of the console and battery/tray.
Re: 2005 Neon 5 Speed ??? Linkage broken?? [Re: B5 Bee] #1401979
03/16/13 10:04 PM
03/16/13 10:04 PM
Baltimore, MD
MadMax58 Offline
MadMax58  Offline
Baltimore, MD
The rage-tek are made of delrin and are held on by c-clips. The booger bushing are made of polyurethane and are pressed on and do not have clips. The rage-teks are easier to work with.
