Re: 5.7/6.1 Hemi retrofit actual cost?
[Re: mopartruckguy]
#1401935
03/17/13 12:48 PM
03/17/13 12:48 PM
Posts: 6,008 Salem
Grizzly
Moparts Proctologist
Salem
Here is what I have come up with so far:
Motor mounts $336 Headers $600 Flex plate $133 Radiator/fans $700 Kickdown cable $128 ECM flash/wiring $1,999 Milodon oil pan $419 Fuel pump $211 Regulator $179
TOTAL $4705
Some of the parts may not be necessary, but I would rather overestimate than underestimate. What am I missing?
Ouch.
As you go along and your list gets as detailed as Cnxt's, that number could double.
If you go the carburetion route you'll have to throw a pricey intake manifold, gaskets, throttle cable, kick-down, and perhaps valley pan too.
From the posts on here over the years I have come to one conclusion: It isn't worth it, and it certainly is not a straight-forward task.
I'd be curious to know from a total, "start from scratch" all-new purchase/build/install, which would be cheaper: a Gen 2 or any Gen 3.
Mo' Farts
Moderated by "tbagger".
[Re: mopartruckguy]
#1401939
03/18/13 07:38 AM
03/18/13 07:38 AM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
I just went through the fuel system upgrade on my 5.9 Magnum swap.
You either have to try to buy or build a baffled the fuel tank in an attempt to keep the fuel pump submerged when you get below about half a tank or run a surge tank system. From what i've seen out there from aftermarket tank manufacturers and do-it-yourself kits, their tanks are really only minimaly baffled, are mildly effective and are pretty expensive.
Surge tank systems are less expensive than a custom tank and way more effective at providing air free fuel even at very low fuel levels with a stock tank. I used a Radium Engineering surge tank with internal EFI pump.
Unless you run a returnless style system, you will have to plumb a return line to your tank. I used 3/8ths supply and return.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
