10.5" or 10.95" Clutch ???
#1401815
03/13/13 10:18 AM
03/13/13 10:18 AM
Posts: 903 Saskatchewan, Canada
cudabin
I know that the original clutch for my 1970 440 six pack Super Bee was the scalloped design clutch with a 10.95" disc.
Any reason to not use the Centerforce dual friction 10.5" clutch behind a basically stock 440 six pack? Probably will make 450hp max after the rebuild?
Stock flywheel and bellhousing...
What do you 4 speed guys use??
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: 10.5" or 10.95" Clutch ???
[Re: 68LAR]
#1401818
03/13/13 05:26 PM
03/13/13 05:26 PM
cudabin
I just talked to centerforce, and the 10.95" is apparently discontinued, so I guess I will try the 10.5" after all...
Thanks,
Arnie
