Disconnecting power steering hoses without a mess #1401455
03/12/13 08:14 PM
03/12/13 08:14 PM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
Is there a smart way to disconnect the power steering hoses without draining fluid all over the engine and floor?
Re: Disconnecting power steering hoses without a mess [Re: conv440] #1401456
03/12/13 10:05 PM
03/12/13 10:05 PM
Modesto CA
BFASTER Offline
BFASTER  Offline
Modesto CA
You just have to use a drainpan and replace it when your done. Dont know any tricks.
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
Re: Disconnecting power steering hoses without a mess [Re: BFASTER] #1401457
03/12/13 10:17 PM
03/12/13 10:17 PM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
Guess so, I was thinking you could siphon the fluid out of the pump but you can'r really get a hose down in there. Also wondering if you could maybe pinch off the return house and try to direct it into a drain pan. Trying to avoid having ps fluid all over the k-frame.
Re: Disconnecting power steering hoses without a mess [Re: conv440] #1401458
03/12/13 11:00 PM
03/12/13 11:00 PM
IN
ahy Offline
ahy  Offline
IN
It helps to spray the K and any area that will get oiled with simple green or similar first. That and a pan and maybe plastic drop cloth will make clean up easier.
Re: Disconnecting power steering hoses without a mess [Re: ahy] #1401459
03/13/13 02:55 PM
03/13/13 02:55 PM
try spraying it with water first before letting the oil hit the metal OP, a turkey baster works good for sucking fluids out of a container, just don't use the one you cook with
