Break In Oil #1401296
03/12/13 12:54 PM
03/12/13 12:54 PM
Mount Airy, Maryland
scrag Offline OP
scrag  Offline OP
What is a good oil for breaking in a RB Stroker motor? I will be running a hydraulic roller cam, Edelbrock heads....in the past I would pass on the synthetics but thought I would ask to see what the current opinion is. Thanks
Re: Break In Oil [Re: scrag] #1401297
03/12/13 12:59 PM
03/12/13 12:59 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
With the roller you won't really need a SPECIAL break-in oil like you do for a solid cam, but it hard to find an oil much better than Brad Penn. Not the cheapest out there but its a very good oil.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Break In Oil [Re: scrag] #1401298
03/12/13 01:06 PM
03/12/13 01:06 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I used 30 wt. Joe Gibbs oil for the last break in. Rings seated very qiuckly. Nitrided flat tappet hydraulic cam, no problems. Used Joe Gibbs multi weight for the first 500 miles after the 20 minute cam break in. I use Brad Penn for post break in. Brad Penn break in oil would have probably worked fine too, but my machine shop had experience with Joe Gibbs oil and wanted me to use it.
Re: Break In Oil [Re: scrag] #1401299
03/12/13 03:36 PM
03/12/13 03:36 PM
tucson az
frank Offline
frank  Offline
tucson az
Brad Penn
Re: Break In Oil [Re: frank] #1401300
03/12/13 03:53 PM
03/12/13 03:53 PM
Bradd Penn/Joe Gibbs oil gets good reviews. On a side note for your upcoming breakin regarding ring seating you might peruse "breakin secrets" at www.mototuneusa.com (5 minute read)
