http://www.ebay.com/itm/MOPAR-Hi-Rev-ECU...052&vxp=mtrRick Ehrenberg special. Anybody using it? Thanks.
"Here's a hi-performance hot-spark hi-rev-capable (min. 7500 RPM certified) ignition ECU control box for all '72-'80 Mopar cars and trucks - Dodge, Plymouth, Chrysler - with OEM electronic ignition Also fits all earlier Mopars that have been retrofitted with the factory system (using stock-type coil and ballast resistor). Replaces all 4-pin and 5-pin ECUs with NO modifications, plug and play. Works with 4-pin or 5-pin ballast resistors, again with NO modification. Made by an original Mopar / Chrysler vendor, but with latest super-reliable all-silicon SMD technology. Comparable to the MP "chrome box", better than "orange box", yet it looks very similar to the OEM stock unit, for that "stealth" appearance!"
